murphys roller rockers
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Topic: murphys roller rockers
    Posted: 23 Jan 2011 at 5:31pm
for those of you who have a set for the 201-226 heads,
 I need to jockey some rocker ratios around.  Is the shaft offset from it's original position twards the pushrod side of the head, or is it centered above the rocker arm studs like original?
in the pictures the stands use a top plate so I can only assume that there is a countersunk bolt holding the post to the head, and 2 bolts holding the halves of the stands togather.
Thank You
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 6:20pm
they are offset
