One-Ninety Update...
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: One-Ninety Update...
    Posted: 22 Jan 2011 at 9:08pm
I've had a few people ask how the One-Ninety is coming along so I thought I'd post an update.  The rear end is finally back together, several thousands of dollars later, and it drives and shifts so much nicer.  I was amazed at the inprovement I couldn't believe what a difference it made.  After my test driving was complete we backed the One-Ninety back in the corner and got going on the motor.  The motor was in pretty good shape overall, it always started good even in cold weather and run good but used and leaked alot of oil.  When we got it torn down we found no broken rings, but the oil rings were not sealing.  The sleeves looked real good on the inside but had some signs of electrolysis and one was much worse than the others.  For a day or so,  I toyed with the idea of just putting one new sleeve in it, but in the end I just decided to put a overhaul kit in the thing and be done with it.  Camshaft and crankshaft and block all looked good, the crankshaft is still std.  The fuel pump and starter also also rebuilt.
The motor is currently going back together once that is done it will be run a while and then will get painted.  I have most of the sheet metal painted already.  I hope to have this project completed sometime in May of this year.  Just wanted to share.  Thanks.
Matt Folkers
FOLKERS RESTORATION
Olsem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Olsem Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:13pm
Cool....good job...nice shop too.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:26pm
Wow, what a project. (nice shop too)  Keep updating...
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:54pm
^^^^ What they said. I grew up on a 190 it ran really good. One day I was plowing and unhooked the plow hooked the disc up and stoped to open a gate and she would not move they said there was a bearing in the tran. that locked up and  we got rid of it. It then when to a sawmill. I seen it at a local parts guys yard (all states ag parts in downing Wi). they told me it was running a saw mill they did the screwdriver thing and blew it up. It was said to see it there. My dad on the other hand said it was a good place for it.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 10:33pm
Old Doug, Like your pics, Like your shop too! When you get her all back together and got the new coat on, it'll sure look good. Something about those old 190 XT's they had a nice look.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 10:50pm
Finally going to have a nice painted match for your manure spreader. Looking good Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 11:41pm
Way to go. Can't wait to see it done.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 11:38am
Did you have much pitting in the lower bores of the block?  I had to use some epoxy to fill in the pits to make sure the o rings had a good surface to seal to.  Also, Sam T. filled me in on a tip with those engines: use vegetable oil, not a petroleum based oil/grease, to oil the sleeve o rings.  Good luck!
Hurst
1979 Allis Chalmers 7000
5800 Hours
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 6:24pm
Hurst
Vegetable oil or dish soap will work too. Just have to flush the block out before you run it or it will foam up from the soap. Petroleum oil or grease will swell the o-rings almost immediately and then you are stuck getting new o-rings or you cut one and don't know but will find out one day the hard way.
Wink
I am a Russian Bot
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:25pm
Hurst
Well there ya go, I learned something today.  veggie oil or dish soap.... mental note made....
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:52pm
Now don't forget. LOL
Jim seIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim seIl Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 8:47pm
J D you know green has a sleeve soap that I use and like I haven't had any ill effects with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2011 at 9:31am
Good looking project , they can be alot of work ,but its worth it !!! Just curious what all you done to the tranny ? I luv runnin the Hundred series tractors , but that dam tranmission , i hate stopping just to change gears , and every time it grinds I tell myself - I,ll have this one apart soon !!!
