IB available for restoration or parts
StanInLowerAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Topic: IB available for restoration or parts
    Posted: 19 Jan 2011 at 10:13pm
I found an IB in a local salvage yard that can be bought.  Any thoughts on what should be invested?  Most of the main parts are there--engine, trans, both final drives, frame for attachments, front axles--will have to have hood, grill, radiator, fender, 4 rims one rear wheel center weight misc small parts like mag/dist. starter etc.  This is just from visual inspection I know that there is a lot of work to do if it can be saved.  Question is what is it worth to be able to make it worthwhile.  Any comments welcome. STAN
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 10:30pm
Most of the needed parts are readily available on the thousands of B's available. Buy a good B, the junker IB, and you'll have an IB in no time.
are genuine." - Mark Twain
Mark J. N.Y. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark J. N.Y. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 10:51pm
don't let this one get away................... IB's are hard too find....................
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 6:55am
Once you know what a reproduction frame costs, you will snatch that one up and rebuild it. Don't wait too long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 8:28am
Are you referring to the channel frame that wraps around the tractor for mounting attachments? BTW what does one cost?  TKS Stan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 4:47pm
Stan,
 That IB should be in your garage by now! Grab it!!
Steve@B&B
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 5:04pm
Stan , save that IB !!!
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:17am
Norm Swinfords book lists IB serial numbers before 1946 having B ser. numbers.  After that year, does the numbers prefix with IB? and are any numbers more significant than others? Also the total production for IB model is 2850.  Any guess as how many may have survived?  Thanks, Stan
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:28am
Yes the prefix will be IB as of 1946, as with any a very low serial # might be more interesting but probably not of more value than another.
