2wd 6080 frontend |
allis6080
Topic: 2wd 6080 frontendPosted: 19 Jan 2011 at 11:55am |
would any one know were i could find a complete 2wd front end for a 6080? my spindle bushings are junk and the rest of the axle is extreamly loose!! or know of a way to put a narrow front end under it. I plan on pulling it alittle in farm stock class. thanks for any input.
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1154 |
Posted: 19 Jan 2011 at 1:36pm |
Are the 6000 series and the later 170/175 axles the same or do they just look very similar?
Craig/insoh
Joined: 26 Mar 2010 Location: Waverly,ohio Points: 229 |
Posted: 19 Jan 2011 at 2:50pm |
6080 has heavy duty front end others have same front as 175. We put a 6080 front on 175 after tierod failure while hauling a 2000 lb round bale. I had to make a set of bushings because 175 had smaller diameter pivot pin.
BrianC,Ont
Joined: 11 Sep 2009 Location: Belleville Ont Points: 903 |
Posted: 19 Jan 2011 at 3:46pm |
Someone suggested to me to put a pedestal and nf off of a D19 on the front of my 6080.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
allis6080
Posted: 19 Jan 2011 at 4:24pm |
so brianc,ont they said to basically take the whole narrow front end off a d-19
BrianC,Ont
Posted: 19 Jan 2011 at 4:54pm |
I had posted earlier that I wanted to make our 6080 4wd into a narrow front puller. And they said to use the D19 front pedestal and fab it to the 6080 frame rails. Or if you could find a 100 series pedestal and nf might work also. I am going to put a D17 wide front under ours because they wont let a nf front pull in the 6500 lb and over class.
