voltage output wd45
rubeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubeman Quote  Post ReplyReply Direct Link To This Post Topic: voltage output wd45
    Posted: 17 Jan 2011 at 7:01am
1 wire alternator on wd45. when tractor is running, the voltage gage reads 14.5v. Why then when I check voltage with me tester anywhere in the circuit, the tester won't show a constant voltage. Different voltage readings flash so quickly, you can't tell what the reading is. Your help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 8:20am
I would say you are not getting a good ground with tester or tester needs to go into the trash can.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:04am
Do you now anybody with an analog tester? Might try one of the old fashioned ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:38am
I contacted a guy that sells have the 12v conversion items and he told me the same thing. Digital dosen't work on old tractors with copper wire, points etc. Says there is frequencies
that interfere with the digital type.
This page was generated in 0.079 seconds.
