WD-65 Project
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WD-65 Project
    Posted: 13 Jan 2011 at 4:05pm
262 Project soon ready for paint mechanical work finished
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 4:06pm
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 4:07pm
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 4:12pm
Ok,I'm getting this BUG too.... Guess its time to find a motor!!!!! Lol.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 4:25pm
I am just glad I am in the assembly stage. Drove it around last summer and worked out all the little bugs/adjustments.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 6:15pm
looking good,willbe great when your done!
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 6:32pm
Do you have any ways to do videos? I found that people really like update videos. Looks good.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 9:45am
Is that a WD tranny? Some say they can hold more torque than a WD-45 tranny?
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 2:28pm
looks like a 45 shifter but i can be changed so idk
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 3:08pm
I think it is a bent WD shifter or a custom job, a 45 is tapered with a ball on the end
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 3:53pm
I don' think WD and WD-45 shifters are interchangable....but I could be wrong
In the other hand, replacement shifters for the -45 are not taperd, and do not have a ball end, just truncated like the one in pic, at least not the ones I got from Sandy Lake
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 3:55pm
What is the motor?
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 6:08pm
ya its curved more at the bottm more i c .............but iv seen a 57 wd 45 that had wd parts and a wd shifter
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 6:34pm
So the 57 had a WD tranny in it cause you can't mix em.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 6:39pm
Lou that would be either a 230 or 262 gas engine.Likely a D19 engine(262).Either one needs the D19 governor if out of combine.
 stick a 45D rear plate and flywheel/clutch assm on back and yer good to go.
Edited by Steve M C/IL - 14 Jan 2011 at 6:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 11:44pm
it come from AC like that they bought it new
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 9:03am
That shift lever doesn't look like ether a WD or A 45. It's too big in diameter. Maybe someone made it.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 10:53am
Dusty
I have a couple of AC replacement shifters that I bought from Sandy Lake that are that thick, the original were not that thick, but the replacements apparently were, and just cut off at the end, no ball
Wait for the Lord;
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:53am
In regards to the tranny shifter the tractor came with this larger diameter shifter lever and yes it is a 45 tranny. It wasn't made up looks to be original. I know another guy how has a WD-45 with this kind of lever and tower that came with his 45. This tractor did very little work ! have the history on it. Engine was distroyed because of a lack of antifreeze. The tractor never got repaired and sat up in a barn for years/years lift arms and drawbar have almost zero wear. I believe its the original shifter. The engine is a fresh rebuilt 262 combine engine with D-19 govenor on it. Linkage to control the govenor is from 45D. It sound really nice at 2500-2800 RPM. Allis Should have had this originally in a gasser. Looking for a nice 4 furrow semi mount plow for it.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 10:28am
If it came with the 6 cyl. in it it must have been a Diesel to start with or a picker tractor.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 2:10pm
no it originally had a 226 4cylinder in it with this shifter lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 4:15pm
What motor are you using now,Zyta and what problems have you encountered???
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 5:08pm
This is a 262 combine engine. Removed the combine govenor and installed a D-19 govenor work excellent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 6:23pm
262 out of a combine is this the only choice,or is there others?? Was thinking on doing a diesel but not now,that I seen a gasser.Converting a gas to diesel would involve a little more work Imo.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 8:24pm
Is the manifold/carb still in the Skunk Works secret lab????
That JD air filter fits nice. We got that adaptor plate thing on the money.
Edited by Calvin Schmidt - 17 Jan 2011 at 8:26pm
This page was generated in 0.097 seconds.
