Need Allis G Double Tool Bar Dimensions
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Topic: Need Allis G Double Tool Bar Dimensions
    Posted: 11 Jan 2011 at 10:19pm
Hey guys. I have some Planet Jr wheels, cultivator shanks, clamps and shoes and want to build a double tool bar for my Allis G.  I need dimensiions to accurately recreate one.  I've shown the didmenstions on the enclosed image.  Could anyone who has one measure it and send me the dimensions I've marked?
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 6:02am
I will get these measurements for you when I get home from a business trip.
I should have gotten back this morning but it's been pushed back about 24 hours.
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 8:52am
Thanks Scott.
That's terrific.
Dick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 12:38pm
Dick,
I have 3 of these double-bar cultivators at my home near Atlanta, GA and a 4th at my dad's farm in Indiana.  I am not able to examine the Indiana cultivator at this time.
I remember dad talking about "Willie Ecker" cultivators - Willie was a local welder that apparently built these double-bar for farmers in the neighborhood.
In looking at the 3 cultivators that I have access to here in Georgia, I think one is a Willie Ecker model, one may be home-made or maybe not and the third one appears to be an Allis-Chalmers model.
The only reason I think the 3rd one is "stock" is due to the fact that it matches the drawing in the manual exactly.  The one that I stated was "home-made or maybe not" matched pretty closely but it only has 2 drilled holes (not 5) to receive each of the mounting bracket legs.
I will use the cultivator that appears to be stock Allis-Chalmers for the dimensions that I'm going to list.
I'll post the dimensions for the mounting brackets in the next post.
A= 1 1/2"
B= 3/4"
C= 12 3/4"
D= 63"
E= 28 1/4"
F= 25"
G= 9"
H= 2"
I= 2"
J=2"
K=1"
Notes:
E is measured to the opposite side of the angled brace's width - weld might have influenced the measurement (everything else is pretty much round measurements) but 28 1/4" is what it looked like to me.
F is measured to the closest side of the angled brace's width.
G, H, I, J & K are all measured from the end of the bar-stock to the center line of the hole.
The drilled holes take a 3/8" bolt easily but not a sloppy fit.
It appears that the "C dimension" pieces are set in about 1/4" from the end of the "D dimension" pieces.  Distance from one "C dimension" piece to the opposite end "C dimension" piece is 62 1/2".
Scott
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 1:10pm
I sure am glad you are getting good use out of that book, show us some photos when you get the unit built !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 1:11pm
Dick,
I am uncomfortable with the accuracy of most of my measurements on the mounting brackets.  Measurement "N" being the exception: N= 6 1/2" and is 3/4" x 2"
What I'd like to do is take the brackets off the cultivator, trace the bracket on a piece of paper and mail it to you.
Send me a private message with your address and that's what I'll do.
Best regards,
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 1:20pm
One more thing about the mounting brackets.  The "bent" part of the assembly is the same bar-stock as the rest of the cultivator - 3/4" x 1 1/2".
The part that is defined by the "N" dimension is different bar-stock - 3/4" x 2".
Best regards,
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 9:22pm
Dick,
Got the tracing done and will get it in the mail tomorrow.
When I took off the Attaching Arch Assembly, I found 2 bushings in it.  I just pulled out my Parts Catalog for Model G implements and, sure enough, bushings are mentioned.
I think that confirms that this really is an Allis-Chalmers Double Tool Bar.
I measured the holes as best as I could and it looks to me like they are 5/8" and then the bushing was inserted.
The forward hole is centered 1 1/8" from the end.
The rear hole is centered 11/16" from the end.
Note:
The ends of the arch assembly are not "neatly" cut.  As a result, the measurement from the end to centerline of the hole was difficult to determine with complete confidence.  The above measurements are as close as I could determine.
Best regards,
Scott
Edited by Scott(GA) - 14 Jan 2011 at 9:25pm
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 4:57am
I may have to try my hand at making one of these someday ! I have a single tool bar, might just make an add on for it !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 7:57am
Dick,
An additional note regarding the drilled holes in the cultivator "frame" (G,H,I,J,K)...
Regarding these holes I had written the following note:
I was looking at the Implements Parts Catalog this morning and I noticed that the Attaching Arch Assemblies call for 7/16" bolts to attach them to the culltivator "frame".  So that defines those holes better than my original note.
Best regards,
Scott
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 8:53am
I believe that that most pieces when manufactured are cut by shearing and holes are punched, which is why they are a little hard to get a good measurement.
Dusty
contrary_farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote contrary_farmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 6:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 9:26am
I've looked closely at the pictures and I can't see the "open-V cross-brace" (my terminology) that should be there.
Best regards,
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 6:14pm
That person has several pieces for the double tool bar on ebay AND thinks they're all made of gold !!!!
