A.C. 7040 oil leak
NYREDPOWER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NYREDPOWER Quote  Post ReplyReply Direct Link To This Post Topic: A.C. 7040 oil leak
    Posted: 11 Jan 2011 at 8:14pm
Hi Im looking at a 7040 has 5000 hrs on it but is dripping transmisson oil . I couldnt really see where it was coming from are there places to look thanks.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:50pm
Do you have a general location where it may be coming from, like for instance between the engine and tranny, or farther back, left side or right, etc.? I still may not be of too much help to you, but if you can narrow it done a little, other very knowledgeable people on here can probably shed a little light on it for you. Also, I see you just got on board, so welcome.Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote NYREDPOWER Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 7:41pm
Sorry I didnt explain further The tractor is outside at a dealers . There is a large oil spill under the back of the tractor. Couldnt really see where it was coming from Im going back to look further when its running. I guess my real question should be is there a common place to look for transmission fluid leaks and is there a seal between mtr and trans that  leaks and would have to split tractor to repair thanks in advance and really like your forum
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 8:33pm
My guess would be leaking seals on the gerotor pump where the pump slips into the rearend housing to begin with. Next the gasket between the piston pump and power steering pump. Then square O-ring seals on the supply tubes to the piston pump (2) and the power steering pump (1). Change both hydraulic filters and replace O-rings on the covers. Finally the gasket under the suction screen to the gerotor pump. Each one is probably leaking on a unit that old. Been there-dun that.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 12:48am
sometimes my 7010 leaks a little oil, comes from behind the pto shaft. i replaced the o ring once and that took care of it!
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 10:19am
It could be as simple as a leaking hydraulic line.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote NYREDPOWER Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 7:50pm
thanks for the answers what is this geroter pump? these thing sound as they can be fixed without spliting the tractor.
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 1:25am
There is also a screen filter in the accumulator housing, if memory serves correct.  The get cleaned out and the plate cover may not get put back on well enough.  it's about 6 or 8 inches square.  Anyways, could be lots of stuff, but that is one option with an easy fix.
