How to make a G a "high Crop"
Corbincdc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Topic: How to make a G a "high Crop"
    Posted: 11 Jan 2011 at 4:43pm
I grow vegetables on raised beds and need a bit more clearance with the bottom of my tractor and my cultivation equipment.  I have been thinking of two things.  First, I could get larger rims and tires. I have also seen people modify the axles?  Do you know of any resources? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 4:57pm
Oh the Tractors are  G's
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:15pm
Here's a picture.
http://www.tractorshed.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.tractorshed.com/gallery/tphotos/a6318.jpg&firstrec=1&lastrec=15&Parameter=&mode=All&what=tphotos
Dusty
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:20pm
this won't be a store bought thing, you will have to build it you're self
Here's some food for thought-
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:39pm
Corbincdc; please remember that all "hi-crop" tractors have a significantly higher center of gravity (than normal tractors), and therefore are more vulnerable to rolling over when operated on a hillside, or going through a ditch, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:42pm
Why not bolt a set of B or C finals on and then add your wheels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:46pm
seen that before -
from the 2010 G roundup
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:48pm
Ok this may sound odd but..
If the beds are just '1 G wide', could you add concrete blocks or 8by8 timbers along the edges to lift the G up higher?
yeah, I know silly idea, jes another way of looking at it !
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:52pm
So if you used C finals, would the 30 inch G wheels bolt up. If not you could alter the wheel centers to make it so.
I would think, if you add the B finals and leave the 24's on it, you would be REAL slow in granny gear.
Edited by CTuckerNWIL - 11 Jan 2011 at 8:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:09pm
yea, and just  the opposite when you add bigger 30-36-38 inch tires.  Your speed will increase by the ratios of the diameter. For instance, if you have 24 inch tires and low gear is 2 MPH, if you install 36 inch tires that is 50% bigger so you will go 50% faster or 3 MPH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:15pm
All I was thinking is, if you start out with 30 in tires and have the normal speeds, if you add the C finals with their normal gear reduction, the tractor would be slow with 30 in wheels and even slower with the 24's.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 11:26pm
By putting on the B or C axles, wouldn't you also have to flip the ring gear?  Is that possible on a G?  I know guys used to reverse WC's all the time.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 7:16am
I guess you would John, I hadn't thought about that.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 11:02am
I use concrete railroad ties for my raised beds....just drive the 175D up on them and drop the Howard rotovator for a one pass job. I then plant everything close together so it shades out the weeds....just takes a little work with a hoe.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 12:10pm
Thanks guys.  I'm thinking I will go with the bigger tires and rims and modifying the front end. Similar to Joem's first post third picture down.  What size do you think those tiers are? I was thinking maybe 13.6 by 38?  Could I go bigger? Besides modifying the rims and front end are there any major concerns?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 12:25pm
I was also looking a a 9.5 x 42?? What's your thoughts? too big?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corbincdc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 12:33pm
Also where would I go to find a rim for a 9.5 by 42 tire
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 1:06pm
http://www.millertire.com/
 Go to rear rims: then flat base and you will find 10-42 or 8-42.
acgman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acgman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 5:18pm
Our G Hi Crop has 7:00x36 rears and 4:00x15 fronts. If you ever by Muscatine ia. we are just across the river by Joy Ill. and you are welcome to take measurements off it.  Thanks Dave.
AKA.ON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AKA.ON Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 9:57pm
Is that row crop G factory? That is one cool looking tractor.
D12 Series II, D12 Series III, 170, B, U, WC forklift, Cockshutt 40.
