WD buddy seat
Central WI AC guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Central WI AC guy Quote  Post ReplyReply Direct Link To This Post Topic: WD buddy seat
    Posted: 10 Jan 2011 at 10:53pm
Hi all! I recently bought a WD with a belly mower and would like to modify the seat on it so that my 6 year old son could ride safely. I remember seeing on the forum someone who added another seat mount off of the brake cover and made a wide seat going all the way across. Anyone have pics of this or know who it was that posted it? Thank you in advance!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 11:02pm
Here is a pic of my buddy seat on the WC, seems like I remember a bench type seat on one but don't remember who did it.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 7:47am
Rick M made this one for his WD45, You can send him a PM about it.
Don
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:02am
Don't know if this is Ricks, but here are a few more pics...
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 9:48am
I'm pretty sure John's photos are of Adam's here in NC... NCAllisNut
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 12:49pm
in most cases, the passenger does not have the steering wheel to hold on to.  A hand rail in front of the passenger might be a nice added measure.  Probably needs to be hinged so you can mount from the front.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 1:47pm
Does this one count? Its on an AC 712 with chains for the woods run.
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 3:07pm
Hey Kurzy, that's pretty neat!
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 6:48pm
John has the in procress pics of mine above - here is the whole story.
The frame is made out of 1x1 angle with two pieces of flat bar welded to the bottom with holes drilled and tapped to attach the frame to the seat supports.  I used a WD support to match my original seat support.  I added a piece of metal to the lower shock mount to keep from drilling a hole where my serial number is, so the shock mount is attached to the brake centering bolt.  A WD45 support would be better, since they bolt at the brake covers only.  The back rest is made out of 1/2" conduit.  I had the cushions made at a local auto upholsery shop.  I think I was inspried by Rick's seat with the two D17 cushions on it, but I wanted one solid black cushion more like a C.
Since you can't get on from the back with a bench seat in the way, I built this step.  It makes it easy for me and my kids to climb on.  It is made from 1x1 tubing and 1x1 angle iron.
Adam
RickM(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 7:05pm
Don, I can't take credit for building mine since I bought it from a fella up in MN. Mine is mostly bolted together instead of welded, but it is attached just like Adam's using an extra WD seat bracket assembly. I don't have near as nice of a front step as Adam's to get on from the front.
Missouri Allis Chalmers Club Member; 1954 WD45 (NF), 611LTD & 811GT Lawn Tractors
crowlk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crowlk Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 11:01pm
looking to put a bench seat on my 53 wd   can you send me pics and ideas?
thanks so much
kevin
kjcrowley2@gmail.com
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 11:08pm
Aal the pictures except dons are just a blue question mark. Any one know why?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 8:12am
Here are some pic's of mine.
Taylor in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taylor in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 8:14am
Being a thread from 2011 i would say most likely because whatever site they had hosting their pics either they no longer have a account or their link address has changed.
1941 B 1957 D17 1968 IH 3514 Early 190XT Gleaner F
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 12:26pm
I know, Dakota Dave. I have the same blue boxes all the time on my phone. If you ever find the answer please pm me.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 12:45pm
Im liking the wide seat, you guys are pretty clever, looks like it would be especially comfortable for us bigger guys. Well done, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crowlk Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 8:05pm
did you just move a brake cover from rt side w bracket to left side?  I wasn't sure they were interchangable
Post Options Post Options   Thanks (0) Thanks(0)   Quote crowlk Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 8:16pm
looks awsome
did you just use another rt sided brake cover on the left side with bracket? didn't know if holes matched up
garr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 9:42pm
Why can I not open pictures or what do I need to do?  A lot of time someone talks about how something looks but I see nothing  What am I doing wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2014 at 9:51pm
The bracket from the right side will bolt on hype left side. I picked up an extra seat assembly a few years ago to do this on my wd45 but never did. I have a cab and couldn't figure out a reasonable way to be able to flip the seat so I could get in. I took the extra seat bracket off and hung it in the shed. Maybe some day I'll finish it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 7:53am
You're not doing anything wrong at all.  The pictures are GONE.  They have been moved, erased, acct. closed, for whatever reason, they are no longer shown because they aren't there.  You can't find them either.
A lot of it is because certain accts. can only have so many pictures in it and then guys delete the old ones and upload new ones.  The old (now deleted) pic is just not there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 10:28am
Here are the pics of the bench seat I built back in 2009.  I think the links died of old age, but the pictures are still in my folder on this site.
Adam
www.facebook.com/AdamDavisWoodworking
garr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garr Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 12:13pm
Thank you for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 2:56pm
It would be much easier with wd-45 seat brackets, instead of trying to stay original to the wd and using original style brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crowlk Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2014 at 1:00am
interested in selling it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote crowlk Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2014 at 1:03am
are yours wd or 45
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 11:39pm
I needs one for my big butt!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 2:46pm
I got NUTHIN to say to that....
This page was generated in 0.430 seconds.
