D10 3rd gear
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Topic: D10 3rd gear
    Posted: 09 Jan 2011 at 9:39am
Anyone with experience fixing a D10 that jumps out of 3rd gear?
What causes it, and how to fix it?
Thanks, Bill B
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:05am
Could be a number of things... Back pinion bearing. The splines on the gear. The splines on the shifting coupling wore from grinding. Open up the side panel see what it looks like. Look for metal shavings at the bottom of the casing. check the play the shaft has. check the splines on the gear and the coupling.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:06am
I have had a D10 tranny apart. :)
"Better By Design"
This page was generated in 0.219 seconds.
