WD45 Carb with throttle shaft?
John_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_B Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Carb with throttle shaft?
    Posted: 06 Jan 2011 at 4:35pm
Has anyone bought the tISCO brand "complete" carb kit for the TSV464 ? and if so does it include the throttle shaft and packing?  The sellers don't seem to know if it does or not. thanks.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:34pm
  IT IS NOT TSV    IS TSX 464 COMPLETE KIT WILL HAVE THE SHAFT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 5:04pm
Depends on the mfr whether their complete kit includes the throttle shaft. My kits do not include a throttle shaft, but gives you everything needed to do a total rebuild. In a lot of cases, a throttle shaft isn't needed. The bores wear before the shaft. Drilling the bore and pressing in a sleeve or bushing, then installing the new seals usually does the trick for another 20 years or more...
Steve@B&B
