Unstyled WC hand crank
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WC hand crank
    Posted: 05 Jan 2011 at 7:08pm
Where did the hand crank mount on a unstyled WC with a wide frontend. The unstyled WCs with a wide front or single front wheel had the detachable starting crank.
Anybody have a picture of this.   Thanks BILL
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 7:44pm
through the hole in the forward part of the tool box..
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 7:53pm
Hey Bill, this might not be the original spot, but we mounted the hand crank onto the Oak board on the back of the tractor, with metal broom clips. I know its not original, but it sure works good. Also, this is a 1938 unstyled WC with narrow front, and it had the detachable crank.
This picture was taken before we put the clips on, but they are mounted to the far right on the oak board now. Should take a newer picture someday.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 8:13am
Don -- that's a nice looking WC ya got there!!
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 8:21am
There should be a set up similar to a WD except mounted to the left side frame of the tractor.  I am not sure if it is correct but thats how ours is, and it works good.  Here is a picture if you can make anything of it or not.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 8:28am
It loks like the crank on wide or single front WC ,is the same as WD and WD45.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:42pm
Have seen several unstyled WC`s with narrow front with the crank mounted on brackets on the right front frame rail.These were 37 and 38 models.  Not positive, but they sure looked like factory type brackets similar to the type WD45`s used on the inside left rear fender.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 9:07pm
Two great looking WC's on here. I like the wide front. I have one to put on one of our WC's. I wish we had a wartime WC with the square rear end for it. I also like the OAK lumber on the other.
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 6:34am
BILLP: What a great problem to have!
UNIT3: Come to Indiana, I have two of the steel rears if you have a tractor.
