Off Color John Deere B question
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Off Color John Deere B question
    Posted: 05 Jan 2011 at 3:17pm
What weight gear oil is used in the rear end and how full do you fill it/where is it filled? Also, where is the fill hole for engine oil and what weight it that? Grandpa always knew about the Deere, I just know the basic stuff. I had all this stuff written down, just can't remember where I put the paper.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 9:23pm
Trans & Rear End use Gear OIL  80/90 will work Fine Cap, 4/41/2 Gals.     Motor oil filler is on the right side top of motor by belt pulley  its a pipe cap use motor oil[your choice]  oil level check valve is on right side below belt pulley  oil filter is on bottom of engn. Cap.6/8 qts. dont forget 1st. reduction gear thats the pipe plug behind the oil pipe drain plug is behind belt pulley Cap. about  1/2 qt. use motor oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 9:32pm
  Trans Rear End filler plug is on the back right by P T O no dip stick  if it runs out its full if it dosent put some in.
