Splitting 190XT III Transmission
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Splitting 190XT III Transmission
    Posted: 04 Jan 2011 at 1:32pm
4th gear flys out on your 190XT III. The splines  on the 4th gear ( which is one with the input shaft) don't look to healthy and I imagine the shifting coupling isn't to good either. What I am trying to figure out is...can I just split the tractor in the middle, without having to take the rest of the tranny apart, and also take that coupling out once the input shaft is out to replace it. Or will the countershaft gear be in the way not letting me get it out....which would require the entire tranny to be taking out. Any info would be appreciated.
Edited by Austin(WI) - 04 Jan 2011 at 1:33pm
"Better By Design"
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 1:56pm
I'm thinking you'll have to drop the c-shaft down to get all the stack off the mainshaft.Ya know they're all basically the same from WD45-220,just incresed sizes.Been through both 45&220 but too long ago.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 4:41pm
Sorry Austin,   4th gear will come out with just  a split,  in order to get the coupler out the main shaft has to move to the rear of the tractor,  wheels, axles, bull gears, brakes, ring gear and housing all gotta come out.
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 4:46pm
This is what a fourth gear teardown looks like.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 4:47pm
It might just be that front bearing for the input shaft...that is number 1 on my things to look at.
"Better By Design"
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 5:08pm
I like this picture doug, i can just see the caption "What did i get myself into.."
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 5:23pm
Oldoug says " Oh man, what's that piece down in the bottom? I didn't see that before."
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 6:29pm
whew!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 6:45pm
It's "now what part goes where"
Wink
I am a Russian Bot
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 7:44pm
190XT transmission rebuild. When we worked in the
service dept. at the Des Moines branch, Joe Dullard and I put on
service schools on the 190XT power train in 1966 and
1967. We would get 2-4 dealer's mechanics together
at one dealership and we would basically replace everything
but the castings from the torque tube back. We did 19 of
these schools. The fix that we installed was supposed to
be the final time that they would ever have to come apart.
It stopped the bleeding, but there were still some problems
after that.
The flat rate was supposed to be 28 manhours, but none
of the dealerships could even get close to that. We would
give them all the hours credit that Milwaukee would let us
get away with.
  Anybody know where Joe Dullard is and what he is doing now?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:53pm
Worn shift fork on 4th gear also contributes to the problem.  My XT is almost back together from getting this problem.  New input shaft, bearings, shift fork = plenty of cash, but should be good for a long time now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 11:24pm
We put a new fork in because the other was really wore...now it flys out even more frequent. I will have to check the play in that front input shaft.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 1:31pm
you may be able to modifly the shift detents on the shift rail to improve the gear jumping.   Also on a lot of those tractors the counter shaft can jump up and touch the coupler  while 4th gear and knock it back to neutral.  also the snap ring on the mainshaft may need to be a little thicker to keep the gears from moveing on the shaft.   HTH
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 2:29pm
Hey Dean, I thought I remembered seeing an old service bulletin about using "torque lock" gear sets as replacements parts for older tractors. Could that have been true and I wonder why didn't Allis ever come out with these better gears as repair kits for earlier tractors if it's not true?
Wink
I am a Russian Bot
