D 17 fuel bleeding
Ollie Oliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ollie Oliver Quote  Post ReplyReply Direct Link To This Post Topic: D 17 fuel bleeding
    Posted: 28 Dec 2010 at 11:24pm
Hello I have a diesel D 17 that I changed the fuel filters on, and now, how do I bleed the air out? I'm used to (excuse me) Oliver's and IH's where there's a hand priming pump to bleed the system, but on this old gal, there isn't such a thing, any help would be great, thanks.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 11:43pm
Aren't the filters below top of fuel tank(fill it up)?Don't they have bleed plugs on top of bases. Let gravity do the work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 12:28am
I used a shop vac to prime mine. I loosened the hose at the pump head then put the vac hose on the outlet side of the vac and used it to pressurize the fuel tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ollie Oliver Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 8:24am
Hey thats a great idea, I just might give that a whirl. Thanks for the help
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 10:15am
Also once you get clean fuel to the pump, crack an injector line at the easiest injector to get to. We always pull started them to save on starter and batteries.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ollie Oliver Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 1:12pm
Thank you very much for the advice. I did the shop vac trick and it worked like a charm, it's up and running, and I bled each injector line too, thanks again!
