b oil pan
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: b oil pan
    Posted: 27 Dec 2010 at 11:56pm
Can the oil pan come out without removing the front axle from my B ?  Its a cast iron pan if that makes a differance. it is leaking bad and I want to replace the gasket.
John
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 12:49am
Yes it can. The hardest part is getting to the bolts that are back inside the bell housing. Once you get those out and the pan loose, move the pan forward, drop the rear portion and slide it out.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 10:52am
Some will come out without moving the pivot plate forward some and some will not.
I have had several B's that the pan would not come out any which way it was wiggled. I posted pictures a while back of pans that were slightly different/longer on the corners.
Edited by Dick L - 28 Dec 2010 at 11:09am
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 4:58pm
I would add the style of cast iron pan is a factor as well. Here are three of the different styles I'm aware of.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 9:16pm
I think mine is the one to the far right
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
