wd power steering question
dsgraf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsgraf Quote  Post ReplyReply Direct Link To This Post Topic: wd power steering question
    Posted: 25 Dec 2010 at 12:52am
looking at a char lyn gear for power steering on my 1952 wd and wonder why you can't use the factory hydraulics to power it? is there a reason why this won't work and has anybody tried or done this. my only use for tractor is plowing driveway in winter and backing trailers in. please coment.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 12:58am
The high pressure and low flow system of the factory hydraulic system is not compatible with the Char-lyn system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 7:34am
Even if you could plumb in a priority valve and a relief valve to get the pressure down to what you need,you probably wouldn't have enough volume and you wouldn't have steering when you push the clutch in.
This page was generated in 0.095 seconds.
