45 D head bolts
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: 45 D head bolts
    Posted: 22 Dec 2010 at 4:07pm
 having problems with a couple head bolts seeping antifreeze, took them out and put thread sealer on , still leak, very frustrated , any suggestions, also cant seem to seal up pan gasket, have a few oil leaks, this is after a major ovh on engine
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:10pm
Where is the pan leak? At the rear? On my 262 build, I put a thin bead of sealer all the way around the pan, the rear sealing ring, and the rear cam plug. If you have coolant coming up a head bolt, I'd be wondering if the block had cracks around the hole. My 262 block had cracks around 10 of them. Did you have your block hot tanked and magna fluxed?
