50 B engine problem
case580 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote case580 Quote  Post ReplyReply Direct Link To This Post Topic: 50 B engine problem
    Posted: 20 Dec 2010 at 4:56pm
I removed the head on my 50 B to fix a broke bolt and install a new gasket. While I was in the process I removed the oil pan and cleaned the bottom end really well. I resently reinstalled the head and today I turned the engine over (using the starter) for the first time. My problem is, only the #2 intake valve is moving, none of the remaining valves are moving at all. I realize I may be asking to broad of a question but I have to start somewhere. Tell me what additional information is needed to solve my problem.
Thanks
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:05pm
When you dropped the push rods in could they be off to the side and not lined up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote case580 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:13pm
I noticed when I dropped the puch rods back some wanted to drop down further than others. After messing with the push rods I have all of them sitting at the same height and each one is tight up aganist the rocker arm. Is this a timing problem or maybe a bad cam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:18pm
I don't think they should all be at the same height, whether it's timed right or not because of the lobes of the cam. I'd pull the rocker arm off again and double check where they are sitting.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:29pm
Are the rest of the push rods moving up and down when the camshaft is turning?
Post Options Post Options   Thanks (0) Thanks(0)   Quote case580 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:34pm
none of the other push rods are moving only the #2 valve rocker and push rod. Currently all the rockers are sitting basicly at the same height and all the push rods are snug up against the rocker and the rocker is snug against the valve spring. Could I have stuck valves?
Edited by case580 - 20 Dec 2010 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:38pm
Are the rest of the push rods moving up and down when the camshaft is turning? The push rods will not be the same heigth when they are sitting on the lifters correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote case580 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:41pm
okay, well I must not have the push rods sitting correctly on the lifters. I tried to center the push rods in the holes going through the head and make sure the rods were vertical. I will go double check the position of the push rods.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:49pm
The push rods should not be even when they are in correctly.
This is how mine sat as I was removing them.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote case580 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 6:26pm
finally getting around to updating this post. I didn't have several of my push rods seated properly. After I got the push rods seated correctly on the lifters and under each rocker arm everything looked to be operating correctly.
This brought up another question.
How do I adjust the valves? I got the tractor running today and best I can tell it runs fine (seems a little under powered when pulling a hill). No obvious timing problems but I would like to know if the valves are adjusted correctly.
If I have #1 Cyld at TDC on the compression (intake) stroke how do I measure the valve adjustment? After I get #1 Cyld set how do I proceed to the other 3 cylinders?
Thanks for the help!
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:21pm
Do you have a service manual?  If not, several vendors on this site (parts link in the top right corner of this web page) sell them.  Here is a link for a World War two technical manual for a Model B ( http://carl.army.mil/wwIItms/TM9_782_1942.pdf ).  It is free to download and is 4.2 MB in size.  Page 36 (of the pdf file / page 32 of the original manual) briefly covers valve tappet adjustment.  Basically get the valves so neither one is trying to open and set the clearance to .010 hot (ABOUT .012 cold).  Does that help point you in the right direction?
Edited by RyanTN - 02 Jan 2011 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:40pm
When the piston is on the compression stroke both valves should be closed. That is where you set the gap. I have heard .011 or.012 cold will get you close to .010 hot. When number one is coming up on TDC that is the compression stroke. Each cylinder will follow in order of the firing order.
