governor housing Allis B
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Topic: governor housing Allis B
    Posted: 18 Dec 2010 at 7:02pm
What is the best way to cure the oil leak around the post that the throttle linkeage and oil line hooks to.
The post is loose, I could pull it out.  I tried Form a Gasket and it didn't seem to work. I was thinking of JB Weld however it's only a little bit loose, just loose enough to leak.
Any suggestions would be appreciated.  Thanks
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 2:54pm
JB Weld did the trick.  I took the post out and clean the hole and the post.  I used a wax and grease remover and a q-tip in the hole.  Just a thin coat of JB Weld on the spline on the post and tapped it back in.  24 hour cure... hooked everything up - No leak and now the post is nice and firm too.
