AC 6060
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060
    Posted: 15 Dec 2010 at 12:33pm
What kind of diesel engine do I have in my 1983 AC 6060.
I have a small drip from the front crankshaft seal. How hard is this to replace? I have replaced seals in some engines by dropping pan and loosening the Main caps, letting the crank drop slightly. This works if the seal is 2 piece.
What am I looking at on this engine???
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 12:35pm
The engine would be a 433t allis chalmers make. Its 200ci 4cyl and 3.3 liters
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 2:18pm
if i remember ita a fiat / allis .. do you have the front block so the crank dont slide ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 2:37pm
It's an Allis Chalmers engine, 4 cylinder version of a 301 used in 190's for instance. Front seal replacement should be done from front of engine, and you dont have to drop pan, but may have to remove front cover. good luck, Ed.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:23pm
If it doesn't have the add on external thrust bearing mounted in front of the crank pulley you may have more going on than just a leaking seal. They were known for crank bearing problems because they didn't have thrust bearings initially as that engine was originally designed for belt drive applications. A leaking front seal was often the first sign of trouble. I don't mean to scare you, just sayin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:27pm
thats what i was tryin to  say .. but didnt know how to say it .. thanks allisfreak
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:34pm
No problem sir.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:37pm
No problem sir.
and just to amplify what you said .. we were one of them that didnt get the update notice .. yup the crank slid and ruined the engine . put that block on afterwards .. after all the damage had been done ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:48pm
That sucks. That was a big oversight by A-C engineers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 8:59pm
I guess I don't know what you're talking about. I don't remember having anything in front of the of the crank pulley. Does anyone have a picture of what I should be looking for?
Thanks
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 9:25pm
no pic..but look for a grease zerk and block toward the front end ...
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 9:34pm
it is a three-bolt assembly that surrounds the front of the crankshaft and pulley with a bearing in it.  Some refer to it as a "bra" for the crankshaft to prevent it from sliding forward.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 9:45pm
I did the crank seal on my 6080 a few years back.  Did not need to remove the front cover or oil pan.  Mine is a 1985 model so the crank shaft movement problems were resolved by then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 7:44am
Do you know what was the first year that the problem was resolved?
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 7:59am
When I go out I'll get the serial number so we can make sure what year it is.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 8:01am
The clutch caused the problem, it was same trust brg that had been used in 190's, 185's. 7020's. The clutch was a Luk 2 disc with 2 throwout brgs, at a service school when this problem started showing up we were told that if the PTO lever was pull back for PTO disengagment and the foot clutch was pushed in for transmission disengagement and the pivot pins were binding from dirt {worn clutch disc material} you could have as much as 800 lbs pushing the crankshaft forward. So the taper roller brg was added to the frt of the crank. You should never operate with the PTO lever pulled back for longer that it takes to put PTO shift lever in or out of gear.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 8:49am
The 6060 6070 6080 engines were 4 cylinder versions of 2800 -2900 engines. Same bearings as piston cooled 301's. 6060's had few problems since they were equippped with smaller clutches. The larger clutch in the 6080 resulted in super heavy thrust loads on the thrust brgs on the crankshaft.  The tractors would only crank with the foot on the clutch and the hand clutch lever for the pto pulled back.  Since the engines at first had lower compression ratios due to a higer boost level at mid to upper hp range the thought was to lower compression to keep engine life up - alass as in pulling tractors.  Problem was lower compression ratios caused hard starting.  Thus the engines were cranked way too long with little or no oil pressure - thus wearing out the thrust brgs and crankshaft.  Many low cost attempts were tried as a fix like slotted brgs.  The 'fix' was to install a secondary thrust bearing on the front crank bolt to assist the thrust brg during starting and pto clutch loads.  NOTE if I had a 6060-6070-6080 I would install a safety start system that would not let the engine start with the seasonal disconect (the lever on the rh side) in gear or the trans shift lever in gear. This would allow the eng to crank withour pushing in the foot clutch or the had clutch for the PTO, this will take the pressure off the crank thrust brg.  Again only if a positive non crank in gear system was put in place.
Human safety is more important than iron preservation.   Late sn engines after 33k-21863 had double wide thrust brgs and a wider thrust area in the crankshaft itself. They did not require the front bra kit. Be careful when changing or swapping cranks.  Anyone who has built a 301 or 433 has found the old blocks have a wire edge that will prevent the wider brgs from fitting in the block. The block will accept the late brgs if the sides of the block that prevent the brgs from fitting in the saddle are filed down smooth. No problem, easy to do.    Late engines were equipped with higher compression pistions and smaller  .032 orfice tips.  They cranked much better in cold weather. 33k-20381 was the cut in sn for high compression pistions, best of my info. Older engines on F2's and K2's with  the 201 ci engines had the old AC injectors.  These all had the low compression pistons as well. The advantage to these were that IF the correct ether system was used they would crank without the ether knock and damage that occurs when excessive starting fluid  is used.    Hope this helps.   It is rare to have a front seal leak on these engines as the front seal does not rub on the crank itself, but if the crank does move back and forth it is a tell-tale issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 8:52am
Great information. I wondered why there was a indicator light that let you know the pto was disengaged. Man, I have been operating with shift lever in gear and lever pulled back!!!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 1:15pm
Can I still buy the bra kit for my engine? I don't have one and my engine number is 33K-14741. Would like to install one when I replace the seal.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 3:49pm
I don't know if you can get them from Agco anymore or not. Possibly from a salvage yard. Google Mark Heitman Salvage in Wisconsin, he may have one.
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 4:05pm
We put one on last spring and was available from AGCO
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 4:13pm
Tbran - thanks for any additional info on these engines. On the older 433T or 433I engines before 33k-20381 sn - is the correct ether system for the 433s where the can of ether is inserted into the engine's either setup and then applied from the cab of the gleaner k2 combine?  If I choose to just use the intake heater element is that ok if I don't want to use ether or does this require too much start cranking hense causing premature wear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 9:30pm
Do you remember the cost? Maybe part number?
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 1:26pm
Bump
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 2:24pm
Part # 70274413 Available $364 Will also need hardware to put it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 3:08pm
Thanks Dale,
This has been really informative.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 5:30pm
as to the ether, as long as it is applied via the nozzle while cranking, one is ok.  Later model 433I 's had DUAL heating elements. IF one had a good pair of batteries this would really work until about 29 degrees and then the engine would run and die for many restarts and the batteries just wouldn't hold up usually.
JK(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 5:35pm
I have always been a little confused by this issue. So when you operate the tractor you should have the PTO engaged even if you are not running a PTO implement? I'm not exactly sure how the levers are set up. Is there a neutral setting in the PTO lever as well?   -  I'm curious becasue I'm looking for a 6080.  thanks -
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 5:59pm
Yes, the pto consists of an engagement knob that you pull up to engage, push down to disengage. This actually uncouples it from the drive gears in the transmission. There is also a long lever that you push forward to engage, pull back to disengage. That is the one that puts all the stress on the crank bearings when it is pulled back. The knob is to be disengaged when not in use so you can leave that long lever in the forward position, thus relieving the stress on the crank bearings. That is why the yellow warning light comes on when the long lever is disengaged (pulled back) to remind you that you are stressing the crank bearings. Confused yet? It was an obvious afterthought by the engineers at the eleventh hour.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 6:59pm
Just wondering, but if the crank seal leak is from the thrust bearing problem, wouldn't that mean that the crank has a lot of end play and at a minimum the main bearings should be replaced (at least the #4, I think that is the number, main with the thrust bearing)?
Hurst
1979 Allis Chalmers 7000
5800 Hours
