G Model Engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Topic: G Model Engine
    Posted: 13 Dec 2010 at 10:49pm
Starting to tear down my G for this winter's resto project, and was wondering if anyone knew of an outfit that sells a reman G engine. Preferably on the East Coast....TIA!
Steve@B&B
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 12:21am
Not exactly sure, but don't limit your search to "allis chalmers G engine". The Continental N62 engine that was used in the G was also used in the Massey Harris Pony, and I think a few other things as well, so keep an eye out for them also.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 2:06am
Trouble is the N62 that fits a Pony won't fit a G. The starter is in a different location. I think the only difference is the block, that all the parts interchange, but in a fixed bore block you need the block to fit the tractor. Its not sleeved so it has to be bored when the cylinders are worn.
Gerald J.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 9:41am
Cylinder heads are different too.  Ponies have a neck for the upper rad hose cast into them and the G has the bolt on neck that sneaks around the fan.  I looked into it when my head got stolen (among other things).
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 9:51am
Steve, I am heading East in Jan, if you find one in the midwest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 9:52am
Valu-bilt used to show the same head part number for Pony and G I thought. For years they had new replacement heads. But they don't admit it today on line.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 10:02am
And their 1995 catalog shows no head for the Pony, only the G but they show they same gasket kit for both which should work. Maybe they learned the G head and the pony didn't work.
Gerald J.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 10:43am
Just bring me the the engine. i am getting ready to do one now ,complete over-haul. Just as well do 2 of them.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 10:46am
Sounds like the way to go Big Cat.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 2:15pm
Ya know what ole' buddy? I was gonna have you do that engine when the machine was at your shop and I forgot bout' it. A mind is a terrible thing to waste. I'll drop it off the back of the machine and get it to ya providing I can find yer' house. Thank you for the offer Big "D" !!
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 2:36pm
When I rebuilt mine I found a place 25 miles from me that had several NOS N62 blocks that were for fork lifts they were the same as the G block except they had a place for a water pump and the hole for the oil filter was not bored I made a plate for the water pump and bored  the filter hole and built a good engine. If anyone is interested I can check to see if he still has any of them
The head from a G will work on a Pony but a Pony head will not work on a G.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 3:18pm
Steve,Sounds like you got the engine covered. Now your gonna have to find someone to rebuild the carb. LOL
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 6:30pm
And while he's at it have him rebuild the starter and generator. You will want good stuff on that new engine. LOL
singingpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingpig Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 8:27pm
You found a sweet deal, there.
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 8:36pm
I believe the governor was different in the G version of the N62.  Allis-Chalmers used a "spider" type governor and I'm pretty sure the Massey-Harris Pony used a ball-bearing governor.  I did find a ball-bearing governor in G112 when I tore it down.  I don't know if this was a replacement or if the first few versions of the G were using the Continental governor.
Best regards,
Scott
