D17 power steering barf...
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: D17 power steering barf...
    Posted: 13 Dec 2010 at 10:17pm
Hi All!
So I went to start my D17 last week, and as it was warming up, it started barfing what appears to be hydraulic fluid, from just in front of the radiator.
Didn't do it for long... mebbie 20 seconds or so... then it cleared up.  I hadn't turned the wheels... just cranked it up and walked away for a minute while it warmed.
Did I have some ice in something, or is this indicative of some other problem?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:57pm
I'd guess the thicker oil made a bigger bubble than ussual. This displacement pushed some oil out the vent. Problem is where did the air come from. Likely have a pin hole in the suction tube.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:04pm
Cold thick oil.Probably caused it to suck air through weak/worn pump seals.
Edited by Steve M C/IL - 13 Dec 2010 at 11:04pm
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 10:36am
It drew air into the system from somewhere.
