7040 PTO?
dualquads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dualquads Quote  Post ReplyReply Direct Link To This Post Topic: 7040 PTO?
    Posted: 12 Dec 2010 at 10:38pm
Did all 7040's have the reversible 540/1000 rpm PTO?  Mine has always had the 540 out and I'm considering buying a rotary chopper with 1000 rpm.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:52pm
540/1000 was standard, with 1000-only being an option.  So you should have 1000 PTO, just remove the six bolts, pull the pto shaft out and flip around and install bolts in the inner bolt pattern..you can only get all bolts in with shaft lined up one way.  Then crawl underneath and lengthen the drawbar.   -Wes
