2010 year in review...pics or posts
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: 2010 year in review...pics or posts
    Posted: 12 Dec 2010 at 5:05pm
As 2010 is winding down, I thought it would be cool to start a thread containing this year in review. Post anything, tractors, trucks, shops, anything cool that you want to. Maybe a project you worked on and completed, or didn't. Post anything you want that happened in 2010, good or bad!
Here is mine, this WD that we are currently working on. A corn picker will be attached to this sometime in the near future. Hope that this gets things kicked off.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:13pm
Heres another, the "sugarbush" got a new stand for the bulk tank. Later the building got a couple coats of red paint.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:14pm
i bought this in the spring looks alot worse than it is. i even got the new tires in the same year...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:22pm
we also had a great time working the ground this year. i love plowing. 8050 with 6x16's and wd45 with 3x14's dad was busy or there would have been a 185 with 4x16's...Jb
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:25pm
Started early this year looking like this.
Now it looks like this.
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:30pm
Here is the money pit D19d
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 5:40pm
I was in my one and only tractor show this summer, won't bother doing that again.  While I had the loader off I had my cylinders rebuilt, cost me $800, hope I never do that again.
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:46pm
2010 for me was the year of high dollars stuck in my rear end...of my One-Ninety project that is.  It started out as a third gear fix, which led to fourth gear, new collar, better shape second gear, ring gear and pinion, and a different rear end housing due to the pinion shaft bearing had spun at one time and somebody just put it back together that way and left it for the next guy...me.  I had thoughts of just parting it out but there wasn't anything good to part out really.  It is back together now and drives and shifts great.   2011 will be the year of the motor and new paint.   I've stuck alot of money into it but it will be most likely the only tractor I ever own and this model is exactly what I wanted.
Matt Folkers
FOLKERS RESTORATION
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:16pm
2010 Was a good year for AC around my place.
Bought the 620 with snow blower, wheel weights, and chains in April
Got this 59 D14 rebuilt and running, and won best original at the local show in the summer
Found out my 6080 puts out a bit more than the 83 hp it is rated at.  Dynoed at a little over 100 hp in the summer
Finally, I bought the D15 II
Almost too much fun for one year!
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:27pm
I changed this:
To this
It sure was a lot of fun.
Our son did this wagon for his 4H project:
Edited by redline - 12 Dec 2010 at 11:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:31pm
Wagon looks really nice Redline!
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:37pm
Our son seems to have a knack for using a spray gun. He is hoping to fix up a tractor for his next project. We have our eye on a WD45 with widefront for him. I hope we can make that work out. We are proud of his talents and are hoping to encourage him more.
Edited by redline - 13 Dec 2010 at 12:49am
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:38am
Fun idea for a post, Don.  Lots of great stuff going on!
After 40-plus years of sitting on flat tires in a corner of the barn, my wife and I unearthed the old kit-built trailer her grandfather used to take camping.  To my surprise, the tires (Ward's Riversides) inflated are still holding air.  Haven't got a clue when it was built.  A Model T friend says the axle is from the front end of a 1918 Model T.  I'm hoping to rig a ball hitch on the D-14 to use it on chores around the property.  The trailer drawbar is a foot higher than the tractor's but we'll come up with something.
1959 D-14 SN/21089 "Martha"
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 9:56am
Dad finally started showing his tractor along with mine. He bought a gooseneck to haul his JD A and my D14 around (in the meantime, Mom had a cow). I really enjoyed spending time with Dad at the shows and meeting new people.
I joined The Butler Co. Antique Engine and Tractor Club located in Morgantown, KY. I've really enjoyed their friendship and look forward to having shows and rides with them next year!
Made a trip to Wisconsin this fall and picked up a John Deere H for Dad. He basically funded my D14 rebuild so I owe it to him to help on the JD.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:27am
I hear ya Oldoug, We got a D-19 diesel, its a whole different ballgame when working on diesels, wallet will get hit hard everytime!
Redline, your son did an awesome job! That is really nice!
Cool pictures, keep em comin!
Edited by Don(MI) - 13 Dec 2010 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 12:11pm
This was taken when I got Lena out of the woods in May 1999.
This was early this summer and she has since had a new water pump,radiator added,and gas tank. Air cleaner is almost ready and the steering wheel is going to Minn-Kota.
And she runs great and was driven around the outside of the shop(not mine).
 I need to get the fenders fixed up and do the wiring for E start and there are a few other odds and ends to finish up. I started on it in the spring of 2000 and had every nut and bolt out of her. I had the engine assembled minus the pan, head, and front cover before my accident so I hired a guy to figure out where I left off.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 12:25pm
Mine is a continuous project. When I find time after work, once the kids are taken care of, and into the wee hours of Saturday and Sunday mornings..... Getting there, couple of little things to take care of and then I can put all my new goodies on.
1954 WD45 NF "Iron Tater"
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 12:54pm
It was a pretty good year. Took a road trip to Indiana and brought home an AC #2 plow. Took tractors to three shows. We got the old 72 combine out for the first time. Bought a 90 for next year, and plowed a few acres so the boys could see how to do it. Got the flatbed on my pickup and painted the trailer. Brought home another IH #8 plow (free and only about a mile from home) Had a road trip up to MI to pick up a snap coupler disk (Thanks Don Snow)
Edited by Dave in il - 13 Dec 2010 at 12:58pm
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 1:11pm
I got to attend the Orange Power of the past along with Bob Henry from Northern Illinois for the 1st time this year. It was very enertaining to see! We watched Dale & his son preparing to do a Wasp Hat Dance after disturbing there home in the baler. Also Bertman starting his pulling capabilities. Bob & I got our exercise covering the show both days and decided that we could use a relaxing cart for transportation for next year!
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 4:57pm
I spent a lot of my summer doing this since we had so much precipitation. Dang grass never stopped growing!
[TUBE]XqEU4E7vF9k[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 5:17pm
Redline, a cow and a calf and some fencing will solve that problem, but you won't get to play on the Orange as much. Or you could rake it and bale it and sell to some Horse collector.  Charlie
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 5:21pm
Well its been a busy year.....got engaged
Bought my first 3 tractors, this being #1 when I got it
and how it looks now
#2 the WC
and #3 I'll have pics of when I get it Saturday....
I also have a new nephew(February 20th) this is an old pic
And have had lots of other things happen as well....mostly good I must say
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 8:12am
Bump, one more day left!
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 11:24am
Here are some pics of the tractor pull in Bellevile Ontario this year. My sister and my dad went. Also all the dignitaries, ie radio and newspaper people got to use dads D15 for their pulloff. Dad is on the left in the last pic. Also another pic of loaded up for another pull.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 11:28am
That is my sister in the first picture. Those D series sure look like a lot more tractor with the 38" rubber on them.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 12:08pm
My little sister had a baby Sharon Amelia Yeagle 05/04/10
Shot a Turkey
Went to Dale's OPOP in July
Fixed my 59 D-17 Thanks Dr. Allis
Lake of the Ozarks Vacation
Built some tree stands
Painted a pumpkin
And plowed some snow.
Big news this year is I quit my job that I have had for 23 years.Opened my own company and I am out on my own now.So far so good.Really like being on my own.Hopefully this Economy can get rolling(I can dream can't I)and we all can have a prosperous new year.Happy New Year Everyone!!!
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 1:29pm
this is the 38 wc granpe helped me buy
 this is the wd i got for my bithday.. thanks mom.
i got this mower
i also got this for my b 10
looking foreword to 2011
but agco is gone and ill miss the orange
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 1:59pm
Did my Dad's baby tractor for him for Christmas!
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 2:08pm
MMy son on my WD-45. I have a C to do this year. Can't wait for spring.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 8:39pm
 The 220 isn't bertman, its Jeff Fultz (jeffinil). That was a fun beginning to a very long day! LOL!
DeWayne
