'39 B part out or save?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: '39 B part out or save?
    Posted: 12 Dec 2010 at 8:26am
I have a '39 b that runs very well but the block has been welded after a rod went through the side. It has 12.4/11x24 tires which I would like to use on my wc. It has an adjustable wide front which I could sell. It has one rivited wheel/hub that I need for my '38 b. I also could use the traney on a C that has a noise in it. The sheet metal is rough but not terrible. The engine is electric start with gen bosses. The starter is bad. It has an ugly homemade 3pt. I have a late '38 b that I plan on restoring and I could use lots of parts off of it. I've never parted one out and can't decide what to do. The motor was rebuilt when the block was welded and it runs good but the weld is ugly and not ac original. I have an extra block but no main caps. Thanks for any input.
                                       Thad
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 8:31am
With all the parts that you are going to save an use and the rest you can sell I would say the '39 is now an organ donor.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 8:32am
You've certainly convinced me that it is a parts tractor, therefore, by the authority vested in me (which is none) I am giving you permission to go ahead and do what you want with it, without any repercussions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:14am
Did 39's come with electric start?   I thought it was 40 that electric start was an option so it sounds to me that the motor was changed out.   If it has a good early gas tank, you may want to hold onto that as the rear mount? changed and the earlier ones are harder to find in good shape and can fetch a good penny.   I bought a 39 once that the engine was tight and it was in pieces only because I wanted the cultivators that came with it for my 40 B.  I think I paid 300 for the whole thing, and I got 250 for the gas tank alone on ebay.
I wouldnt' feel bad parting it out, but make sure you keep a good spare of everything that you can, as it always seems that I sell something and then a year or two later, something else on another tractor takes a crap and then I wish I would have kept it on the shelf.    Then again, the parts I have on the shelf have been sitting there for years and I never seem to need them.   Oh well.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:28am
Always remember this though: If It's got a frame, It can be restored.
I'd rather see thisone parted out than some perfect tractor like I've been seeing lately.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:31am
Yes the electric start was added the tool box is a crank start that has been cut for a battery box and it does have the old type gas tank but I will use it on my 38 because it's very clean and has never rusted. It has a distributer on it that I put on it. It also has one 5 bolt rear hub with b splines inside and a flat b center instead of a dish center like a c. It has a electric start torque tube.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:48am
   sounds like you bought a parts tractor   frt. wheela re different on a 38[cast]  39 [rivited]
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 11:19am
I agree. Even though I'm partial to '39 B's I think it sounds like it's far enough from original that it might be better off used to restore your '38.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:26pm
It's a late '38 b I'm wanting to restore. I've been told the rivited hubs were original on a late 38 is this true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 3:00pm
Thad, here is a link to a previous thread talking about the riveted hubs, and the rear wheel differences.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:05pm
You know, I have trouble "parting out" any running tractor, especially a B.  Remember, they don't make them anymore.  Any one lost is one lost forever never to be replaced.
However, I cannot tell anyone what to do with their property.
Good Luck!
Bill Long
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:37pm
Sounds like it's more of something other than a B with a 39 serial number. They get that way over time with several owners. Not much difference in a late 38 and a 39 when new.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:06pm
The rivited hub/rim ran from '38 (#9019-11799) to '39 (11800-26524).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:53pm
I'm with Bill on having trouble parting out a running tractor. I once bought several Wisconsin AK series engines for parts. Next thing I know, more parts show up cheap and now I have 8 of them that run good. I think I'm down to just a good used crank and a flywheel housing...
This page was generated in 0.313 seconds.
