How do WD45 Wheel Weights Attach
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: How do WD45 Wheel Weights Attach
    Posted: 08 Dec 2010 at 10:07am
I just bought a pair of wheel weights for my WD45 yesterday and I don't know how they attach.  They didn't come with any bolts or anything.  Any help is appreciated.  Thanks, Ted
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:41am
I just use 3/4 inch bolts.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:47am
3/4x3 1/2" carriage bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:50am
What grade of bolt should I use?  6 - 8 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:51am
I have grade 5 on mine only because they were the only grade offered in the length i needed. Grade 2 will work just fine.
tractorchuckie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorchuckie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:55am
grade 6 would work fine. chuck
still looking for the holy grail of Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:04am
What holds them in place while you try to mount the weight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:07am
coordination!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:14am
I'll have to try that!  LOL  Good one.  I was just wondering if you could put a nut on the outside (between the wheel and the weight) to hold them in place?  Thanks, I'm getting an education again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:16am
I have done that with all thread before when I was pulling, before i made a quick tach bracket.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:18am
Ted, you drill a small hole in the shank where it comes thru the wheel center, put a cotter key in the hole to keep them from sliding back thru, then you can mount them by yourslelf.  I set a 2X4 on the rail, then lift the weight on top the the 2 X 4, then use the 2 X 4 as a lever to lift and position the weight onto the bolts.   HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:25am
Thanks!!  That really helps.  Now it should be no problem.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:32pm
I got 3/4 bolts with threads on both ends from McMaster Carr and put a nut on each side of the wheel on one end, and a nut on the outside of the weight to bolt it on. Leave the nuts on the wheel end a bit loose until weight is on or the bolts will angle away from each other and be too wide for holes in weight. You need at least grade 5 if not grade 8.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:38pm
I had mine hanging from cut off gate hinges with nut on both sides  (there not more than grade 2) and I would hang up to 4 on each side, theres enough flat surface to keep them straight. I did bolt each weight on separatly, just for pulling. I have 2 sets bolted on with one bolt ( i think 5.5") but thats only because i leave them there and add suit-case weights  when I need them.  I would pull a disc with three sets hanging like that, I never had a bit of trouble. I changed to a quicker way for pulling just for speed between classes. If you want any more info PM me.
