WD with mounted corn picker progress (pictures)
Message Reverse Sort Order
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Topic: WD with mounted corn picker progress (pictures)
    Posted: 08 Dec 2010 at 12:43pm
I remember it was a day and a half job.   first had to wrestle the picker out of the corner of the mahine shed.   My Dad and Uncle harvestd together so the two of them worked on it.  Once you get the tractor ready, the picker slides on, I block it up and use a come along to winch it on. Once you do it a few times youll figure out the shortcuts.  Good luck!!
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 3:24am
After thinking about it a little more you may have to yake them off but just dont remember that part. I bet it has been 40 years. keep us posted. Dallas
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 3:03am
Don, Nice looking picker. I have put those on many times am iam almost sure you don't take platform and lift arms off. I just don't remember that. there are two brackets that go under rear axle that hold under carriage on. I am sure it will work to take them off but don't think is required. I have a 33 picker to mount on wd when i get some time. It is actually not a hard job and doesn't take long if you have done it before. Dallas
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 11:06pm
Looks great!  All that work to mount the picker but in the A-C lit it was an easy 1-2-3 job!  Your not quite finished with 1! lol
JC the 33 decal is on the elevator, could yours be a regular corn harvester that was the predecessor to the 33?
Jim
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:16pm
Don, Wheres tha corn harvestor33 decal at? On the elevator? Our picker still has some paint on it but I don't ever recall seeing the 33 sticker on ours.
  That picker looks like new compared to ours.
  Dad use to mount the fenders on the tractor sometimes and then again sometimes not, the last time they were left off and been that way ever since.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 9:54pm
Looks like a good job.
Good Luck!
Bill Long
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 9:25pm
Hope you plan on ggrowing a lot of corn for all that work!LOL! Looks like a fun project, especially since you are getting to work with your dad. I plan on doing a mechanical rehab on my dad's C (originally his dad's) after Christmas(OK, at least starting on it.LOL!) It may run into a little longer job than this winter, but if I get to spend time with dad, it doesn't matter to me. Time is hard to come by sometimes, and quality time with people you love is a commodity. Enjoy.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 9:18pm
No gary, will have to wait until next year.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 7:41pm
 Good progress since I talked to you the last time. Did you leave a few rows of corn standing for a test run?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:58pm
looks like you are about all set,  we didn't modify anything, all bolt on after going through the removals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:55pm
Don, Not sure on AC picker, but New Idea needed brake pedals modified. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 6:40pm
Hey all! Just a quick update from fall until now. Busy, busy fall! Have not got as far as I would have liked to on this project, but that just leaves more to do for winter. should keep the winter blues away, time spent in the shop is always enjoyable!
This is my $500 WD that I purchased in september. I have put about that much back into it with parts, but I am not complaining at all! I really like these orange projects!
I tore into one fender tonight, I have to remove the fender, and put "fender extensions" on to re-mount the fenders, to allow for the 70" inside tread width, for the picker. I also was hoping to get that side mounted fan (that you can see in the picture) mounted tonight, but I must adjust the rear wheels first, cause there is no stinkin way to fit it between the brake pedal and the tire right now. I do know one thing, there is a heck of alot to mounting this picker than previously thought! But my dad and I will keep pluggin away at it, we will get it in time.
Thanks again for all you support! There are some VERY GENEROUS people on this forum, you know who you are! I thank you!
Have a great holiday season and merry christmas to you and your family!
Don
All the rear gear on the WD (lift arms, rear hitch, platform) had to be stripped off in order for the gathering unit on the picker to fit on the tractor.
This is the picker that is getting mounted on this tractor, it has mostly original paint.
Edited by Don(MI) - 07 Dec 2010 at 6:44pm
