HD6-G Counterweight
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: HD6-G Counterweight
    Posted: 07 Dec 2010 at 8:00am
Guys: Do any of you know the part number or have a photo of the counterweight used on the venerable HD6-G machine?
I would like to try to find one or two near the east coast if possible. Thanks Orangeman.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 10:14am
Same as the HD5G
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 4:18pm
We have 2 of them off of the back of an hd-5  Will try and get you some pictures might be hard to get them home We are in EWI   Gary Roidt 920 253 8192  they are probably buried in snow
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 5:19pm
where are you on the east coast? i think i have one from a hd5 which is the same. i am in lansdale pa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 4:21pm
Guys: I know your busy with the Holiday seasons, I can wait on the pics.  But still would like to see them sometime.  I have seen at least two different sets of weights.  What manual were the dozer weights covered in?
Coke do you still run your HD 5 or did you part with it for the FiatAllis FD5?
I am in New York State.
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 10:31am
How much for the weight?
mudder45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mudder45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 8:03pm
Hi guys, I have a complete AC 1967 HD6G for sale for parts .everything works and runs, Motor knocks, extra parts motor w/everything that hangs on it, starter, pumps, injectors etc. . bucket has teeth. extra fiber steering clutch discs. owners manual, shop manual, parts number catalogue. new heavy duty bateries.    you can click on the big and ugly to see a picture @ www.equipfind.com/heavyequipment/1967AllisChalmersHD6G
Saratoga NY area. I wish to sell it as one unit rather than part out. The old picture is from an old add I put out. Price, $4000.00 Rick 518-793-5273 or manyflags@capital.net
Edited by mudder45 - 01 May 2011 at 3:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 4:48am
i am thinking $200.00 for the counterweight. i also have a winch on my hd5g that will fit, carco brand, any interest in that instead? i am thinking $800 for that. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mudder45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 1:35pm
With the winch you shouldn't need a counterweight. The winch is usually enough to counterweight.    mudder
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 3:55pm
I still have 1- HD5G, and the FD5 F/A , on the counter weights there were a couple different ones. One set I seen on machine in Iowa had the AC logo cast into it.. My 5 has 2 weights (both seems same size).
Counterweights could be low grade iron and in many cases will not sell even for scrap price. Friend had some from crane he scapped , had to haul to landfill.
 Believe the weights and attachments were in TS5 parts book. Somewhere i have that ?? burried somewhere ??  Like the 20" of wind swept and drifted sonw over weekend kind of puts everything on hold .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 6:32pm
I was just noticing the counter weights on my HD5G are 2 different sizes , dang owned it for over 30 years and just learned something new. Inside weight is 1/3 thicker than back outside one. Inside weight has a cut out (but not full depth of the weight) on top to allow a chain hook to index with top lift pin that is across that slot.  Outside weight is open across top to expose the full pin with it's cutout. Part # cast into outside weight but did not write it down and memory faded.
 Went to move it today to clear snow and ran for 5 minutes and filters pluged up , so another job to do .
This page was generated in 0.122 seconds.
