Removing cab from a 7020?
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Removing cab from a 7020?
    Posted: 06 Dec 2010 at 9:05am
Is it a big job to lift the cab off of a 7020?  I can get it in my shop without the cab, otherwise I have to find another place to do the motor job in it.  I am thinking that I could refurb the cab while it is off of the tractor.  Thanks!
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:46am
If you are going to do an out of frame rebuild, split it outside and roll the front half inside. , Mike
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:48am
Kevin its not an eazy job you have to take the  cab mounts off the axle or the 4 bolts  off the cab then in the cab there are I think 4 half inch bolts and 3 3/8s bolts that have to come out and if you are thinking about taking the steering colunm withit there are 3 other bolts under it and all the wires and 4 brake lines that have to be removed if you have a queston call 1 618 282 2477 and I can explain it a little clearer on the phone Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 1:14pm
Thanks, Neil!
