Allis Chalmers B Hydraulic Questions |
Page 123 4> |
yochujr
Joined: 03 Dec 2010 Location: So. Indiana Points: 122 |
Topic: Allis Chalmers B Hydraulic QuestionsPosted: 03 Dec 2010 at 6:51pm |
I just purchased my first tractor tonight and noticed an issue with the hydraulics. When I engage the pto, the 3 point raises but the lever that controls the up and down of the 3 points appears to be frozen so I can't lower it without disengaging the hydraulics. On the pump, it looks like a throttle body on a carb and it will not move. Anyone have any ideas what it could be and if it's super expensive to fix? Thanks in advance.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 03 Dec 2010 at 7:24pm |
There is really not too much to the whole pump unit. Get a manual, disassemble and clean things and you may need to replace a couple small ball bearings used as check valves. The cylinders should not leak down when the PTO is turned off, that is why I believe you might need to go through the pump. The valve may just be stuck, but what makes things stick is the watered down dirty crud built up inside these things in 50-70 years. Just remove the pump, clean it up and put it on a bench with a nice light colored rag under it. A lip on your bench and a clean floor will help you keep from loosing springs and balls as you remove them, but they can be replaced and should be if there is any pitting on the ball or broken springs. Hope this helps.
yochujr
Posted: 03 Dec 2010 at 7:36pm |
Thank you. So I should be able to pull the pump off the side and get it freed up where it will rotate? Will anything shoot out on me? Thanks for the help, I'm wondering if I should return the tractor or not.
CTuckerNWIL
Posted: 03 Dec 2010 at 7:44pm |
There is no rotating in the pump. There are cam lobes on the output from the transmission and there are plungers in the pump. Each plunger pushes oil past a spring loaded ball and you have pressure. When you pull the pump off the tractor, nothing will "shoot out". It might be just pumping some diesel fuel through it will flush things out enough to work properly. Take the pump off and you will see the inlet line hanging down. Submerge that in some diesel fuel and start pumping the plungers one at a time. Once you have diesel pumped through it, see if you can operate the valve.If it works easier for you, turn the pump uoside down and fill the suction tube with diesel fuel before pumping by hand.
Edited by CTuckerNWIL - 03 Dec 2010 at 7:46pm |
yochujr
Posted: 03 Dec 2010 at 7:47pm |
Here's a picture (hopefully, if I get it to work.) The lever attached to the seat will not move. It's like the small rotating part that it attaches to is frozen. If it just needs cleaned, hopefully it's not a huge deal. If it's something
expensive, I've got a problem.
CTuckerNWIL
Posted: 03 Dec 2010 at 7:49pm |
Disconnect the rod coming up from the hydraulic unit to make sure the handle isn't froze to the seat bracket.
yochujr
Posted: 03 Dec 2010 at 7:57pm |
No, the handle wiggles around and I can move it from side to side.
pumpkin man
Posted: 03 Dec 2010 at 8:16pm |
try spraying it [that thing you say looks like a valve body] pent. oil that should be free mite be rusted up or to much paint on it does it look like its bent check the linkeag all of its got to be free moving
yochujr
Posted: 03 Dec 2010 at 8:30pm |
Thank you a ton for your help. I will go soak it with penetrating oil tonight and check it tomorrow. I have checked and all of the linkages themselves are free but I guess I just can't figure out what actuates the pump or valve body itself. If it doesn't work, I'll try to take a few better pictures and maybe that will help. I'm going to get a manual but it seems like no reason to try to return the tractor. Thanks again for you help and I might need more in the very near future!
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 03 Dec 2010 at 8:43pm |
there are two sheetmetal circles about 3 inches in diameter mounted on the pump c enter shaft. When you pull the lever, it rotates one of the circles and the other is spring loaded to the first. when you let go of the lever, the spring pops the one circle back to neutral so it stops raising. when you push down to lower, the same happens. Let go of the lever and the circle pops back to neutral... soak the outside with a PB blaster and then do a little prying or rotate with vice grips. Tap in the circles lightly to shock load and break up any rust.. The center shaft you are rotating is pushing on a piston that lets oil go to "up" or "down"... the pump is actually a 2 piston pump that runs off a cam shaft coming from the motor- transmission top shaft.
yochujr
Posted: 03 Dec 2010 at 8:57pm |
Those are the parts that I thought should rotate and they don't. I soaked them and I'll try to pry on them and see what happens. If I need to pull the whole assembly, do I just take out the 4 bolts and it pulls out or do I need to disconnect something on the inside of the transmission? Those circle plates you are talking about do not appear to move whatsoever but I will try to break them loose tomorrow.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 03 Dec 2010 at 9:54pm |
Before you pull the pump you may want to drain the oil from a plug on the bottom of the PTO. If you have a gasket with a dam build in it will hold the balance of the oil in the transmission rear end area and save the draining of all the rear end transmission oil.
The oil is filled from a plug on the left of the transmission case looking forward.
Pay close attention to what is said above. It is excellently stated as to the problems you may be having.
Thanks for taking such good care of my favorate.
Let us know how it goes. Don't forget to get a manual or a shop manual that will show the breakdown of the hyd pump and pto.
Good Luck!
Bill Long
yochujr
Posted: 03 Dec 2010 at 10:10pm |
Thank you both. Being brand new at this, I'm sure I will have more questions but I'm hoping to get it fixed and working because I have a nice blade for it and snows getting close! Thanks again and it's awesome to find a forum with such great people.
As for the fluid, hopefully the manual will tell me what I need and how to change it all. It sat outside for quite some time and was not used much while he had it so I would say I need to drain every bit of fluid, oil and grease and change everything. |
yochujr
Posted: 03 Dec 2010 at 10:12pm |
Do you guys know any good websites to order parts from? I know it is in serious need of brakes as well but my main concern for now is a place to find parts for the hydraulic pump if they're needed and haven't had any luck.
WC7610
Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
Posted: 03 Dec 2010 at 11:40pm |
Check out the parts section of this website. Several good suppliers supporting this website!
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
yochujr
Posted: 03 Dec 2010 at 11:49pm |
Ha, I was so worried about finding out what was going on, I completely missed the parts section. Thanks!
Here are some pics of the new purchase. I got it delivered and with the blade for 1500 so I don't think it was too bad. ![]() ![]() ![]() |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25262 |
Posted: 04 Dec 2010 at 6:41am |
That's a nice clean,well cared for B ! You 'dun good'.Just keep her full of gas, check the oil and have FUN !!
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 04 Dec 2010 at 8:22am |
If you get very much snow you may want some chains for the rear wheels.
Have fun with your new toy, Dusty
steve(ill)
Posted: 04 Dec 2010 at 8:36am |
If you cant get the circular plates loose, then you will probalby need to remove the pump. The 4 bolts just take out, then wiggle out the pump. YOu will see two plungers with rollers at the end. Inside the PTO case there are two cams that rotatae and the rollers run on them and push the two pistons in and out. YOU do have to drain the oil first. There are three 1/2 inch plugs on the bottom of the trans, differential, and PTO housing. You will get 2 gallons total drain. YOu need some thin weight oil like hytrans, universal tractor fluid, or 20 wt motor oil for refill. --- With the pump off, you might be able to set in a gallon can of penetrant and let it soak, or get a better grab on the circular parts. You pump internal obviously works since the 3 point goes up. I would not tear it appart untill i got the circular discs losses. You may not have to disassemble.--- THe discs i believe are pinned on with a small roll pin. Maybe take the pin out and take the discs off and wire brush, then turn the shaft by vice grip to test.
steve(ill)
Posted: 04 Dec 2010 at 8:40am |
For your information, your B is a little bit "special". Most Bs have a wishbone front alxe and the rear hubs press on a splined shaft. A few had a straight front axle that has adjustable width. To go with that the rear alxes were changed to a 5 bolt on pattern like an automobile rim... Thats what you got.. nice unit.
MBolton
Jack up or run the right rear tire up on a couple of blocks and you'll loose less oil and make it a bit easyer to get at the bolts holding the pump on. I use hytran but origional recommendation was 20 wt.
steve(ill)
Posted: 04 Dec 2010 at 8:44am |
YOur tractor also has a distributor and coil instead of a magnito. IF it was built in late 50s, that might be original. IF it was build earlier, then it was retrofit. Post your serial number sometime, its by the shift lever....Foot step on the other side is not original, looks good from this angle.. how about another photo sometime of the step ?
yochujr
Posted: 04 Dec 2010 at 10:05am |
Yes, I will definitely put some more pictures on here. I pulled the serial number last night and it is B120223 so I figured it to be a 1952.
As for the distributor, it has a 12v alternator on the other side so I just figured the thing has been switched from 6v. I know a little bit more about 8ns and when I was looking at them I noticed that was very common so I assumed the same for the or any other 12v so it was easier to start. |
George Davenport
Joined: 20 Sep 2009 Location: Trenton NC Points: 127 |
Posted: 04 Dec 2010 at 3:13pm |
I've got a 52 B and I would not take 1500 for it. I think you got a very good purchase. Yours looks better than mine also. I know you will enjoy it in many ways.
yochujr
Posted: 04 Dec 2010 at 8:57pm |
Ok, I've got an update. I sprayed the two outside sheetmetal plates/discs last night with penetrating oil and tonight I was able to break it free by tapping it lightly with a hammer and get the entire lever and entire assembly to rotate. I can also see the center shaft of the pump rotating. Now, when I start the tractor up and engage the pto, the 3-point raises but I still cannot get it to lower, even with weight on it. Any ideas now? I'm a little limited on space during the winter to tear it apart and I don't want to do it outside unless I can get it back up and running pretty quickly.
Also, is there a rebuild kit available that's got all of the valves, balls, seats etc. available if this is the problem? I've been having trouble finding anything as far as hydraulic parts for this tractor, even on this sight unless I've completely missed it. As I said before, this is all brand new but your words of wisdom have already started to build my confidence enough to dig into it. Thanks again for all the great help. |
yochujr
Posted: 04 Dec 2010 at 9:56pm |
Her's a picture of the step that you requested.
yochujr
Posted: 04 Dec 2010 at 9:58pm |
This is interesting. I noticed that the front was adjustable but just assumed that it was somewhat standard for that year. I would be interested in learning a little more about it. |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 04 Dec 2010 at 10:16pm |
You said that you got the discs to rotate. They should be seperated to rotate individually, with the springs creating friction and still allowing them to slip. Bob
yochujr
Posted: 04 Dec 2010 at 10:27pm |
Yes, they do move separately now.
pumpkin man
Posted: 04 Dec 2010 at 10:54pm |
in your last pict. it shows a return hose hook to the filler hole what type hdly. cly is on that tractor could be your prob. show more pict. of the pump & cly. hook up looks like a to way cly. on a one way stym. |
Page 123 4> |
