Allis chalmers ca c axle swap
greg91gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote greg91gt Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers ca c axle swap
    Posted: 02 Dec 2010 at 5:59pm
What do you have to swap, I was going to swap the hole housing and everything but the wheels r different 5 lug to a 6 lug so then I was going to swap out the wheel axle shaft but the bull gear on the c has a big nut holding it i'n and the ca has snap rings any help is greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote greg91gt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 7:26pm
What I am trying to do is replace the hand clutch side of a ca with the right side of a c
Post Options Post Options   Thanks (0) Thanks(0)   Quote greg91gt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 8:54pm
Anyone
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 8:56pm
I was under the impression all you swap was the output shaft from the differential. Do you have any CA clutch parts you want to get rid of?
Post Options Post Options   Thanks (0) Thanks(0)   Quote greg91gt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 9:29pm
is  that also called the bull shaft and if so how do i get it out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote greg91gt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 7:09am
TTT
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 8:50am
The correct name for the shaft would be the pinion shaft. It is the upper shaft that enters the transmission. The actualy final drives will bolt to the transmussion but if you bolted one only it would stager the rear tires . The tractor would move around but you wouldn't be able to do much with it.
The shaft would look like this.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 10:08am
find a shaft from the left side of a  C A
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 10:11am
Pumkin man, from what I was told, the left side of a CA has the same shaft as both C shafts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 10:14am
The tricky part is getting the brake drum off. They can be really rusted in place. The axle clutch can also be tricky to get off the pinion if it's rusted in place I'm told. I rebuilt the hand clutch on my CA and found it was pretty easy. The parts are available last I knew. I'd put the springs in it too. Mine had almost 1/2 inch difference in height old compared to new. If you don't care if the clutch works or not, some folks pull it out and drill a couple holes and bolt it together and put it back.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 10:16am
You did not mention why you feel the need to bypass the Hand Clutch on your CA. The HC is what makes the CA a vert versatile machine. There have been several posts here on rebuilding a slipping HC. Two of them are:
You may want to rethink your need to bypass the HC on your CA. It is not that difficult to do and, unless the ball cups on your HC are really pitted, not too expensive.
Bill Long makes a very good point (in the 2nd post) on grinding down the ears before reassembling a rebult HC. Those that I have rebuilt have had an 1/8" or larger gap when pressed open; I grind the ears so that there is approx.020" gap and have found that they work, and last, better.
However, it is your tractor. There are 2 ways to bypass the HC. The 1st, and least work and expense, is to drill thru the HC Pressure Plates (2-3 5/16" or 3/8" bolts should do the trick and bolt it together (altho some have removed the friction material and welded the pressure plates together). You don't need to mess around removing and replacing the pinion shaft.
The 2nd (and more difficult method) is to replace the 2 piece pinion shaft with a 1 piece shaft. I done this a very long time ago so my memory is a little fuzzy on it. I don't recall if we used a LH CA pinion shaft or a C pinion shaft, so make sure that the C pinion shaft is the correct length. I also don't recall having to remove the bull gear. Just removing the final, inner pinion shaft, HC, HC actuator and cover from the final over the outer pinion shaft. We used a big shop press and press the shaft inwards (altho, some have removed them with a BFH and soft steel drift pin). I recall that there was a key on the shaft that ate up the outer pinion seal when we did this, so you probably want to have new inner and outer seals for the pinion shaft should you go this route. You may also want to be prepared to replace the bearings and races.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 11:43am
Greg - You mention grinding down the ears.  I have my HC apart now and would like to make this improvement before reinstalling.  Possibly you can provide a sketch or picture, Thanks - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 3:55pm
Al
Don't have any sketches available. Install the new friction material on the pressure plates (I like those available from ChrisCT rather than from AGCO, and new springs (if needed) and reassemble the clutch. Take the assembled clutch to your shop press and squeeze it down, if you have more than 0.020 (or so) space between the friction faces when fully squezed down, disassemble the clutch and grind metal off the 3 ears of the parts holding the pressure plates (mark the ears so you grind them square and evenly) so that you have minimal gap. The amount you have to grind off is determined by the amount of gap you have when you squeeze the clutch open the 1st time). Below is a pic of the assembled clutch. The ears you want to grind off are the ones holding the pressure plates together (cap screws pointing up in the picture.
I have found that it helps by squeezing the clutch together when tightening the cap screws. Hope this helps in lieu of a sketch.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:18pm
Al Ive rebuilt two of these and I reface the surface's the disc contacts and then do as Greg said to the ears only do with the lathe also. Also springs are critical check there hight HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 7:34pm
Greg and B26240
Thank for the input I will take to machine shop and get it done. I have New linings, springs, bushings and all new balls. Ha Ha!  - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote greg91gt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 8:58pm
Thank you guys for the replies I ended up bolting it together, I talked to a guy today that faxed me a drill template on where to drill and bolt the clutch together.
stahlhouse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stahlhouse Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 8:27pm
dick do you have any of these axles? what is this axle off of in this picture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 8:42pm
That picture would have been of C pinion shafts from years ago.
