HD11 OIL
Argo2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Topic: HD11 OIL
    Posted: 30 Nov 2010 at 10:05pm
What weight of oil should I use for my HD11 engine in the winter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2010 at 10:57pm
Depending on your location and how cold it gets. If you have heaters on it or just setting out.  I use Rotella 15/40 in just about all equipment year round.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 4:38pm
An article recently published in the  "Equipment Today" magazine (October, page 28) talked about diesel oils in cold temperatures. They state that 10W30 oils will lower starting temperatures 15-20 degree F vs 15W40. I use 15W40 in the crawlers, Bobcat, etc., however thick lubricants do not work well with piston engines in the winter time. Learned that from operating Pratt & Whittney radial engines in the winter. Cold, thick oil is a killer for any engine in the cold.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 5:26pm
 I used 15-40 Mobil Delvac in my Powerstroke and 4150 Kubota for a couple of years and after asking my jobber about lighter oil , he said yea, we can get Delvac 10-30, so thats what I use year round. Makes a tremendous differance in cold weather starting, if I towed heavy loads in 100 degree heat I'd use 15-40 but  I see no temps like that here. Maybe in Tejas.
