175 kicks out of 4th gear
c linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote c linn Quote  Post ReplyReply Direct Link To This Post Topic: 175 kicks out of 4th gear
    Posted: 27 Nov 2010 at 8:15pm
tractor has 1450 hours and falls out of high gear the fork was worn and replaced no gear wear was noted You can hold it with one finger It does not try to jump out just falls out if not held no pressure required
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 8:55pm
It sounds like maybe when the shift fork was replaced a piece or two of the interlock hardware between the shift rails didn't get re-installed. Does the shifter feel like anything is trying to hold it in gear when you engage fourth gear? There should be a spring loaded pin that engages in a groove in the rail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:22pm
If the fork was worn, that tells me that the fork has been trying to keep it in gear but the couppler and gear is worn.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:55pm
There won't be noticeable wear on the gear itself. It would be on the splines that the coupler engages and the coupler itself will wear which cannot be seen while in the tractor. I would check into the possibility of the detent or spring missing first.
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 8:19am
Ours won't stay in high gear, I usually when going down the road keep my foot in front of the shifter so it don't fall out. Now it stays in 4th gear unless going down a hill with a load pushing it will jump out. Also when you shift shift to neutral and let out on the clutch it tries, and sometimes succeeds, to fall into 4th gear on its own. So what could be causing this?
If fishing is a sport your looking at an athlete
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 2:26pm
check shift rail detent first
