WD loader questions.... |
Post Reply ![]() |
cbuttre835 ![]() Bronze Level ![]() Joined: 12 Nov 2010 Location: Peytonsville TN Points: 105 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Nov 2010 at 5:14pm |
OK, on the local Craigslist there is a guy with a WD and loader for sale... says the "loader will need new cylinders per the owner" (owner is elderly, doesn't have internet access, so he's listing it for him).
A couple questions - will this loader and frame fit a D-15? If not, I assume it will fit a WD-45? What do new / rebuilt cylinders run, cost wise? I haven't seen them so don't know why the owner would say that they need replacing... wonder what the "point of no return" is for rebuilding them or replacing them? |
C w/ 3rd gear out
D15 II factory 3 point WD (no motor!)(parts for sale!) WD 45 wide front |
John (MO) ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: NEMO Points: 202 |
You should have no problem making the loader fit. May need a couple new hole in the mounting plates. I've seen the same loader go from a D-14 to a WD to a D-19. Cylinders can be rebuilt, depending on what's wrong with them.
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24458 |
as John says, the cylinders are rebuild able, real cheap. I have a pair that were pretty badly pitted and scratched. I repacked the seal with packing rope and it works real fine, weeps a little more than they should, but works fine. If the loader is a W-9, It will fit a WD/WD-45, but I don't know how much it would take to mount on a D series, like John says, maybe only a hole or two
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
You will have to measure the tractor frame width to be sure it will fit.
I have a loader on a D-14 and want to put it on a D-15, but I know the engine frame is wider. Bob
Post Reply ![]() |
