D14 oil change
papastanh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Topic: D14 oil change
    Posted: 26 Nov 2010 at 7:21am
We just got a 1959 D14. I'm ready to give it an oil change for the first time. I have a Fram C159 oil filter. Looks like it's packed with cotton. I want to know how much oil to use. I purchased 5w30. . Are there any tips that I need to know? I'm new to this, so any help is appreciated. Thanks
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 8:36am
Got a '59 also, papastanh.  Serial #21089.  Maybe yours is close by!  I'm in upstate NY and have always used 10W30 with no problem and the C159 Fram's one of the most popular filters for our tractors.  Just changed oil and filter the other day and as always, it took just a bit under 4 qts.  Following the manual and advice from the forum here, before sliding the new filter with gasket onto the post, pour a spoonful or two of oil into the filter (hole in the center).  Then work the filter down onto the post with a slight back and forth twist and hand tighten it.  Rather than over fill, I usually put about 3.5 quarts in and bring it up to the fill line over the next few hours (or days).  Some have said it's not a bad idea to have a fresh gasket or two for the drain plug, just in case. although I haven't needed one.  And uh, one tip from experience...if using a funnel to send the waste oil into a container, be sure that the funnel spout is big enough to accommodate the flow!  You learn.  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 9:49am
Along with knowing about the stem that goes up in the filter, make sure the old gasket comes off with the filter. 2 gaskets don't work better than 1. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 2:47pm
Hey KP, Thanks for the information. Looking forward to future exchange of information
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 2:50pm
Hey C Tucker, About how long is this stem you refer to that goes into the filter? The filter that came off had an inverted dome inside, with a hole in the center, but it did not appear any object penatrated it. LOL on the double gastket
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 6:15pm
Read this older post. Don't run the tractor without the tube. You will not have proper oil pressure. If it wasn't in the old filter the filter is still clean inside and could still be used.
Glenn has a link on that post to a picture of an old tube. One thing to remember is the tube can be pushed in too far, restricting oil to the filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 7:55pm
Thanks C Tucker, I looked at the link, but that was referring to a Model B. Is this the same sort of tube for my D-14? I will look further at the detail of the base inwhich the filter screws into for any signs of attaching point for this post in question. Thanks
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 9:00pm
The filter base has a 1/4" hole in the center and the tube pushes into that hole and moves the oil to the top of the filter and then it runs down through the filter into the filter base. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 9:44pm
Same thing. Get a new tube from Tony for a few bucks.
Edited by CTuckerNWIL - 27 Nov 2010 at 10:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 6:33am
Thanks everyone for the advise. Who is this Tony of whom you speak?
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 6:42am
here
This page was generated in 0.095 seconds.
