d17 power
panelbeater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Topic: d17 power
    Posted: 25 Nov 2010 at 7:45pm
does the d17 have enough power to run a pto driven round bale machine?
     thanks
http://s2.photobucket.com/albums/y45/panelbeater/
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 7:58pm
  WHAT IS HP. REQUIREMENTS    D-17    54 HP.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 8:03pm
It depends on the size of the round baler. A guy in our community bales with a D 17, but his baler only makes about a 3 and a half foot bale. I've done some baling with my D 19 and a New Holland 850, and that's a load for it, I don't think a D 17 would handle it. HTH, Darrel
acdave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:43pm
a d 17  might pull a 4x5 on flat ground if your not in a hurry i would think in hill it would have all it wanted i use a 4243 massey on mine sometimes it is 75 pto hp on a 5x6 heston and it seems to handle it ok even on smaller hills
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:48pm
I've baled on a 17 Diesel Series IV with a 4x5 case IH baler.  no problem.  we'd run 15-20 seconds past the buzzer to get a tighter bale, it'd lug down a little bit right at the end....
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 1:00am
I used an NH 847 auto-wrap on the D19, it makes a 4x5 bale. When the bale was about 2/3 the size of full it would make the old 19 talk. It was flat ground baling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 5:16pm
thank for the replies, i guess he might pass on it for now
TomSEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomSEOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 8:29pm
If a D-17 won't pull a small round baler, there's something wrong !  I have baled thousands of bales with a 160 and a 483 (4x4) New Idea or a MF 450 (4x5 closed throat )  I always baled in 2nd or 3rd gear high , hills and flat ground as well. HTH , Tom
