d17 industrial
jpecak2010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpecak2010 Quote  Post ReplyReply Direct Link To This Post Topic: d17 industrial
    Posted: 25 Nov 2010 at 12:52pm
hi, does anyone know anything about a D17  industrial w/loader and a heavy attachment called a "sledgehammer" mounted on the rear of the trator, I may have the wrong name for this hammer, its what the guy told us, he said it was used to break up roadways
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 12:58pm
it is called a drop hammer, I have a drop hammer with the demolition head  but dont have a industrial yet to put it on
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 1:57pm
I saw that on CL, that tractor doesnt resemble a D-17 too much aside from the fenders. The hood panels and grill cowling look different. Were they different for an industrial, or was this tractor modified? Or am i just seeing things?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 2:10pm
The tractor shown on the link is not a D-17 but an I-60 / I-600 which utilizes a D-15 power train. The I-60/I-600's did utilize the drop hammer as an attachment. That had to be very hard on the tractor.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 4:04pm
It's an I-60 or I-600  diesel (same if you don't get the backhoe). I have literature on the drop hammer but have never seen one.
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 5:54pm
What powertrain did the I-400 and I- 40 use. Thanks Gary IN
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 6:20pm
  I 400  I40 WAS A D10-12  POWER UNIT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 8:41pm
To be a little more accurate, I-40  and I-400 were based on a D-10 series III. The only difference is the I-40 has 5 bolt front wheels and the I-400 has 6 bolt wheels. The big difference was with the backhoes.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 3:41am
Per AC literature, also please note that some Industrial machines were optioned out by group. So tires, rims, attachments, paint, transmission and engine choices could be selected by the purchaser.   Normally, on tractors equipped with a loader or hoe the rim sizes had a wider cross section to accomodate a wider tire thus carrying the dead load better than say a conventional farm tire from the same application.
Because of the way the machines could be optioned and the passage of time there are number of machines out there that have a fair amount of variability to them which makes things kind of interesting.
