Hydraulic shut off valve.
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic shut off valve.
    Posted: 24 Nov 2010 at 8:18pm
I am looking for a ball valve to put on my WD to shut off flow to my freeman loader. I am doing this so I can run my rear lift arms independent. The best I can find is a brass 600psi valve. Will this valve work or should I look for something with a higher rating? I am surprised how difficult it is to find these. As always, your advice is very much appreciated!
Brian
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:32pm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:32pm
DON'T use a 600 psi ball valve on a 3500 psi system. There are many places to buy diverter valves made just for that situation. I came across a 3 way valve years ago. I ran a pressure line in from the pump and blocked all other ports on the pump. I hooked the loader to one output, the lift arms to another and the remote line is hooked to the 3rd. I push the lever forward and run the loader. Pull it all the way back to use the lift arms and center it to run the remote.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:39pm
With my set up I can have the blade on the back and the loader on the front and run them independently of each other. If you go the ball valve route, buy 2 of them so you can have pressure to  the loader and hold the  the lift arms up or visa versa. You will wonder how you got along without it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:42pm
THANK YOU, THANK YOU, THANK YOU!!! I searched for three hours last night and I couldn't find a link like that.
CTucker, that's really the setup I want. I will look for something like that.
Thank you guys for your help. I don't know why I didn't ask sooner.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:56pm
Most of the selector valves are rated 2000 or 2500 psi. Is that suitable for a WD's pump? Could I get by with one of these since I don't lift heavy loads?
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:58pm
You can buy a selector valve that has a handel so you can switch for which job you want to do.   MACK
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 9:40pm
I had a plumbing buddy of mine get me a 3000 psi WOG (water/oil/gas) valve.  Think my cost was around $20.  I've got it set up so the loader is on it and the lift arms work all the time.  I'd be curious to see a picture of a 3 way setup to hold the lift arms and have the loader.
AaronSEIA
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 10:06pm
I put one of these on my WD quite a few years ago; picked it up at Central Tractor;
TSC still sells them. Works really well. When I lift my bucket to the point I want it, I switch the valve and the loader stays right there while I'm operating the back blade. Then.....I raise the blade, switch the valve again and the back blade remains up as I use the loader. I think it was only about $45.00 back when I bought mine.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 8:41am
If you order one make sure you get the right thread on the fittings. I didn't and had to add couplers. Works great! I can use either as I choose to. Mike
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:24am
Opps I don't think it was the threads but I think the connections were different. Make sure they connect to standard hydraulic hoses.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:55am
Back in 58 when we got a new loader on the WD45, the AC dealer put on an ordenery brass water shutoff valve for the loader. Never had any trouble from it, however they were 2or 3 times thicker than they are today. Would not use todays cheap imports.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 2:25pm
I found a couple different styles of #3000 plus on ebay before. I got enough for all the tractors I will ever buy.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 4:05pm
Find a valve for Sec 80 service , or hyd service, can be a diverter valve with just push pull or lever type. The plumbing valves my work for a while but when they fail what results or dammage to self or others may result is not worth the risk.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 6:00pm
The selector valve that Brian put a link to would work fine for loader and lift arms. If your remote is connected to the lift arms it would work like original. Lift arms come up, then remote would. I wouldn't worry about the 2500lbs rating at all. My valve just has one extra out port and a 3 position handle. I don't know if anybody makes one like it anymore.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:44pm
I put 2 power beyond kits on our John Deere 4450 to run the vac. and fertalizer augers on our planter, I wanted a way to shut them off easy and didn't want to break the bank to do it.  FOr about $65 I used a 1/4 turn "ball valve".  I just ordered them from a hyd supply outfit.  The brand name of the ball valve is Apollo, and I think the rating is 3000 psi. and you can get them with normal 1/2" pipe thread.
