Which Gleaners had a 262 Diesel Engine?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Which Gleaners had a 262 Diesel Engine?
    Posted: 24 Nov 2010 at 7:46pm
Doing a roundabout search based on oil filters, it appears to me it would be the following Gleaners from 1960-mid-1960 had diesel 262's:
  • A
  • B
  • C
  • E
Can someone confirm this?  When were the Series II of the some of these?  Would they have continued use of the engine?
Thanks,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 7:46pm
A i no had it i think
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:20pm
A had a 230-B had a 230- C had a 262- E had a 226.  MACK
corlewfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corlewfarms Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 8:44pm
early f had that engine
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 11:25pm
All F diesels were 301, early gas was 262, later gas was 292 chevy.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 12:13am
Heres the real answer. Only a few CII had the 262 diesel. I have been offering cash for one to prove its existence. Seems none have survived. Had one call from here in SD. Guy told me where he seen one, But it is too far just for me to go peek. Waiting for some pictures of one to turn up but that aint happened either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 7:26am
 I've seen pictures of C-2's with the mighty D262 turbo diesel engine, but never the real thing........kind of like leprechaun's......heard a lot about them, but never seen one !!!!
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 8:19am
I have two 262 TD from C II's.  One I put in a 45 diesel, that I pull a four bottom plow with and use at tractor pulls.  The other one is in a D-17 tractor.  We are running over 100 horse and we have never had trouble with it.  The non turbo 262 put in A II combines.  Both diesel combines A II and C II were very rare.
RSallis-pullinMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSallis-pullinMD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:00am
In the early 70's my dad had a CII with a factory 262t diesel and also an CII gas at same time and the diesel version was much more fuel efficent and more powerful than the gas version.we farmed 500 acres with the diesel until 1979 when we got a 1975 L.
Gordon Chance View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordon Chance Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 7:29am
C2 diesel combines were not that rare on the Eastern Shore of Maryland.  I worked for Shaffer Equipment in Denton Md. and they had one that they used on their farms.  There were 2 in Talbot county around Easton, including Robert Saathoff.  There is one still running on the lower shore that I replaced the injection pump on in January of this year.  There may have been others but those are the ones that I know about.
     Gordon
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 9:08am
I hope a few CII and AII diesels survive. I have never seen one. Although I never think to look and see if one is diesel at any sale.
Wink
I am a Russian Bot
