Allis C steering
Boomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Topic: Allis C steering
    Posted: 24 Nov 2010 at 11:11am
In the process of rebuilding the steering on the Model C with Woods L59 mower. There is excessive wear on the steering link ball joints between the gear box and the front pedestal. Does anybody sell this link, or can I go to a cheaper route and weld tie rods from a car onto the shaft, keeping the length the same. Does anybody know how to measure the taper to compare a vehicle cross reference. I know it will be tough to find a similar vehicle tie rod joint because the clearances will be tight.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 6:50pm
A few years ago at a show  had  a ( C ) that had redone nice job noticed that the draglink had greaseable ends talked to the man about them he said they were Ford Granada tie rod ends pin had the same taper had them cut and welded on who ever did it did a nice job
This page was generated in 0.093 seconds.
