d17 charging problem
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: d17 charging problem
    Posted: 23 Nov 2010 at 5:14pm
I bought a series IV D17 in August. The amp meter was nonfunctioning.  I installed a new one and the needle whips back and forth at high speed.  Is this likely to be the generator? or the control unit or?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 8:46pm
How do you know the ammeter wasn't working? Were you having to charge the battery? Did it show discharge with the headlights on and engine off? Whipping could be caused by a faulty regulator or poor connection.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 10:38pm
Poor sticky contacts in regulator could cause the whipping action. Disconnect battery, then Take cover off regulator. Be careful in keeping things clean. take a point file or sand paper and clean the contacts. then run a clean sheet of paper through to remove any crud left behind by sand paper and then see if that helped.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 7:32am
Never thought of the clean sheet of paper trick. I always blew them off with compressed air. Nice Tip, I will have to remember that one
1968 D15D,1962 D19D
