wd 45 diesel nose cowl
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 diesel nose cowl
    Posted: 22 Nov 2010 at 9:05pm
can any of you gurus out there tell me if a wd 45 nose cowl off of a gas 45 will fit on the 45 diesel.thx
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 9:17pm
I don't think so....my brother had to get the gas tank, hood and cowl off a gas when they converted one a while back.
Edited by Eldon (WA) - 22 Nov 2010 at 9:20pm
ALLIS EXPRESS!
This year:
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 10:31pm
Not sure. I do have one off a WD45D $100.00  785-353-2392
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 9:05am
I believe the only difference is the Hood.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 11:12am
Im thinking the difference is the size of the holes in the two wing pieces that bolt to the frame.  The diesel cowl has large bolts holes.  Thats the only difference I found between the two cowls.  HTH
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 4:59pm
J W - The 45 and diesel Rad. Shells are the same.  The shell for a WD, WD45 with shutters  was different as it had hole for the shutter crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:32pm
thx al i thought that was the only difference,but was not sure,thx again ...
