ID for F&H weights
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: ID for F&H weights
    Posted: 22 Nov 2010 at 1:44pm
I was sorting out some weights today and am not sure how I got these weights or what they fit. Brian Ahart only shows the A-C weights.
The F&H 161 is 19" od and 8.5" id with the holes 7" one way and 12.5" the other way.
The DP2628  is 21.5" od and 8 3/8" id with the same bolt pattern.
What do they fit?
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 2:15pm
The F&H weights I have on my 1958 D 17 are marked W No. 162
Don't know what the measurements are on the hole patterns.
Could 161 fit a WC or 24 inch wheels?
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 2:21pm
161 and 162 are both WC weights. IIRC the 161 has a larger center hole to fit over the hub on the spoked wheels and the 162 goes on top of that.
I can't say for sure on the DP2628
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 2:45pm
I believe the DP2628 was for the John Deere tractors. But they will also fit the same as the #162's
and yes the #161 are the inner weight and the #162 are the outer weight on the WC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 4:29pm
Interesting.  Learned something new on the 161 and 162's.....
I remember posting back when my pictures were taken (on the old forum) about if those weights would fit on my D17 and the consensus was they would (and they do) but no one ever said anything that I remember about the 162 being a weight for the WC's...
Edited by Wil M (NEIA) - 22 Nov 2010 at 4:32pm
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 8:06pm
  161 an 162 weights were a universal weight  will fit many tractors  ih  jd   ac,s moline
   reason for slotted holes remember them in the 40,s an before  my 2 c ents  was a competitor to the rowe fdry weights too
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 7:50pm
Your 161 an 162 f & H weight fit well on the 26 inch (d14 and D15) rims and the 28 inch rims (wc,wd,wd45 and d17).
