WD45 Hand Clutch Lever - Bushing?
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hand Clutch Lever - Bushing?
    Posted: 22 Nov 2010 at 10:20am
I am looking for the bushings that go in the hand clutch lever. Does anyone know part numbers, source? I think there are two.
Thanks
Jeff
Edited by Jeff(WD45-SATX-TN) - 22 Nov 2010 at 10:40am
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 1:29pm
The bushing are 7/8" ID and 1" OD.  I found them at our local electric repair spot. They fix and repair a lot of electric motors. Otherwise Steiner Tractors has them I think
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 8:11pm
  be sure to check the pin it pivots on from the tranny??????seen them worse than lever
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 8:21pm
Hey Norm.
The pin on mine is not in the greatest shape, but usable enough for now. Thought the bushings would get most of the slop out. What is the procedure for changing that pin? Are they available?
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 9:01pm
Have replaced several pins.  Remove the transmission cover and drive the old pin from the inside out.  Remove the right side frame.  Put the new pin in the freezer to shrink it down and then drive it in the same depth as the old one.  With new hand clutch bushings you are back to square one.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 11:13pm
Jeff - I bought mine at McMaster-Carr on-line.  Part number I order was:  2868T192 for a 7/8 ID/1" OD bronze sleeve bearing 1.5 inches long.  I think my plan is to cut them in half and insert half from each end of the pivot.  They were only $2.68 each.  I have yet to put mine in.  I also ordered bushing for my foot clutch pedal as it was even worse.  It doesn't have bushings so I bought a 1 1/8 drill bit and drilled out the foot clutch and put bushings in.  Shaft was worn on it too but it was MUCH better after being bushed.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:35am
I also added a grease zerk after installing a new pin and bushing.
Wink
I am a Russian Bot
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 9:37am
Baum Hydraulics at Omaha (www.baumhydraulics.com) is another source of bronze bushings. 7/8 x 1 x 1-1/2 is their number CB14-1612
Gerald J.
