AC 160 hyd |
John WV
Joined: 30 Oct 2010 Location: bunker hill wv Points: 280 |
Topic: AC 160 hydPosted: 3 hours 32 minutes ago at 11:14am |
i put on a new pump and new allis chalmers power fluid 821 bleed the system and now it will only lift at half throttle with weight on 3 point hitch and moves slow. How can i fix this?
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 806 |
Posted: 2 hours 30 minutes ago at 12:16pm |
Did you clean out the filter right in front of the seat, or check the O ring on that plate? If that screen is plugged or the o ring leaks the hydraulics don't work, or work poorly
John WV
Posted: 19 minutes ago at 2:27pm |
thanks never th0ught about the o ring screen is clean
