6060 rear wheels |
| Author | ||
K bockting
Topic: 6060 rear wheelsPosted: 12 Feb 2026 at 7:59pm |
Has anyone installed 34” rear cast centers off a 6080 on a 6060? i do know will need longer studs , bolt pattern is the same, center hole on 34” casr center seems to be 1/8” smaller than steel pressed 28” rim.
| Sponsored Links | ||
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 12 Feb 2026 at 8:26pm |
Have a late friend that installed the 34's on a 185
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4279 |
Posted: 13 Feb 2026 at 5:50am |
Have a cousin that has a 6060 with 34's off a 6080. Looks great! It came with the standard 28's.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 13 Feb 2026 at 7:09am |
6060 has a Fiat rear,Fiat 8 lug pattern is metric not like US built tractors.There were certain Fiat built tractors that came with adapters and US pattern wheel centers.
Gary Burnett
Posted: 13 Feb 2026 at 7:11am |
Also double check the bolt pattern its very close but not the same on Fiat vs US built
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 14 Feb 2026 at 9:12am |
6060 and 6080 are both made by Fiat, so shouldn't be a problem.
Gary Burnett
Posted: 14 Feb 2026 at 12:13pm |
I'm not familiar with those two models but on some older Fiat built tractors if pressed steel wheels were used they had the metric wheels but if they came with power adjust wheels some used adapters to use US size centers.Just to make life interesting Olivers 1450's could have 3 different wheel lug patterns.
cornel b
Posted: 16 Feb 2026 at 6:55pm |
got some 34 in pressed cemters and power adjust wheels fron a 6060
K bockting
Posted: 16 Feb 2026 at 9:32pm |
K bockting
Posted: 16 Feb 2026 at 9:34pm |
Found a nice set. Thanks
