Tightening the power steering belt on a 160
farmtechguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtechguy Quote  Post ReplyReply Direct Link To This Post Topic: Tightening the power steering belt on a 160
    Posted: 19 Jan 2026 at 4:50pm
My 160 has very weak power steering. I think I tracked down the likely cause being belt is quite loose. I didn't think to check it while it was cold and it's a lot looser then I realized.
Thank you AC720Man for suggesting that.
The service manual shows 4 bolts. Two look like they're tucked in the frame rail. I can see why people are saying it's a pain to adjust.
Any tips or tricks for tightening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2026 at 8:44pm
Will have to look at my 160 tomorrow, kinda forgot how I adjusted mine. I installed a new belt and adjusted. It has to be the exact length belt as there isn’t much adjustment on it. I do remember that. Seams like I used a slight angled pry bar to hold the tension while I tightened the bolts.
Edited by AC720Man - 20 Jan 2026 at 8:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 9:25pm
I forgot about this post so I apologize. There is one bolt that you loosen that the PS pump slides on. I used a small pry bar between the front crank and the PS pump to get the belt tension correct and then tightened the tension bolt.
Wes(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 8:55pm
I second the length of belt.  I think I tried parts houses, but ended up having to go thru agco to be just right.
