Allis Chalmers B project
PeterVD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B project
    Posted: 11 Jan 2026 at 5:04am
I'm Peter, 54 years old and located in Belgium.
I started a rebuild project together with my 18 year old son, an Allis Chalmers B
It runs and drives, but not as it should, so we got a little bit of work in the future
It's already converted to 12 Volt
When I find out how I will post some pictures on the forum
I don't know if this works:
Edited by PeterVD - 11 Jan 2026 at 5:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 8:04am
thats a good looking little tractor.. You have the optional 5  bolt rear wheels / hubs... Most of the Bs had a 2 inch spline shaft that the hub was mounted to..
Good luck.. This is a great place to ask questions..
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 8:18am
Interesting rear wheels,has the center nut like the older B's but the centers are different from anything I have ever seen.Maybe something offered in Europe and not in the USA?Very neat tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 8:27am
your right Gary.. I had to blow up the photo to see the nut.... I THINK there were 3 versions of the axle... one had the center nut, one had the 5 bolt flange, and a third was an ADAPTOR hub with 5 bolts that slid onto the original taper spline shaft... That is apparently what he has..
normally the 5 bolt flange came with the straight adjustable front axle as compared to the wishbone axle.. hard to tell in this movie..
Edited by steve(ill) - 11 Jan 2026 at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 9:03am
Can I just ask how I can post pictures here, I don't find a program to upload them
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 9:26am
at the bottom of this post, on the left, there is a POST REPLY box.. Click on that and it will bring up another page... Click on the GREEN TREE icon in the heading of that page.. At the lower left you can CHOOSE your PHOTO from your computer file  or desktop.....
Files need to be in the 800 x 600 pizel size and will be 100- 200 KB... Most cameras are 5000 x 4000 pixels  and 5 MB in size and this SITE will NOT RESIZE for you.. Do that in PAINT or similar before you upload..
Edited by steve(ill) - 11 Jan 2026 at 9:28am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 9:32am
Steve, you have your photo uploads response in a file to copy and paste? It'll keep a broken record
No disrespect to OP or you. Wish there was an easier way
Edited by plummerscarin - 11 Jan 2026 at 9:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 10:14am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 1:27pm
Peter, sometimes you can get a third party site to post your photos, but the easy way is to have it on your computer or phone and just use the GREEN TREE icon as i posted above..
Some guys post LINKS when they have an album, but a single photo or two is easy with the GREEN TREE.
here is a snapshot of your You Tube video...
Edited by steve(ill) - 11 Jan 2026 at 1:29pm
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 9:07pm
It is a requirement back then that tractors sold in Europe had to have flanged axles to bolt to the wheel.
I wish I could find the source of that info now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 7:04am
I have a Fairbanks Morse FM magneto on the B, I need to change the spark plug cables.
Can I just pull the old cables out of the cap?
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 7:14am
Yes. Make sure you use (copper) wire spark plug wires with a magneto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 8:28am
I ordered a set with a copper wire inside, and Champion J8C spark plugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 9:28am
some  AC engines tend to have problems with the new Champ J8C plugs... Some work OK.. If you have a random miss fire after all is done, keep that in mind.... you may be fine..
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 10:13am
Thanks Steve,
What plugs do you recommend and are they available in Belgium (europe)
In Belgium we have a webshop that specialises in oldtimer trators (named histoparts) and the only plug they have for an Allis Chalmers is the Champion J8C
The only alternative I find here is a NGKB6S
Edited by PeterVD - 12 Jan 2026 at 11:16am
Restoring a Allis Chalmers B
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 11:13am
On the documents I see that mij B is registered in France for the first time in 1953.
The serial number is I0062 en according to google it's build way earlier than 1953
Not so important to me, I just like to know the year that it's build
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 1:06pm
Nice tractor! Big smile
Is the small black box just below the steering arm the battery? Your generator and electrical looks different than the US versions.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 1:24pm
Peter, that serial number in the 10,000 range would be a 1938.. Your tractor has a battery box, generator and starter motor...  General appearance would make you think it was built several years later than that.. Maybe your missing a digit ?   The serial number is by the gear shift lever ... B- XXXXXX... the front wheel  / rim was different on the 1938- 49 tractors... yours looks like the standard 5 bolt automotive type rim that was common on the later tractors..
In the US, the NGK plugs are more common among Allis users of the smaller engines.... Since you have the Champs, give them a try... the might be OK..
Edited by steve(ill) - 12 Jan 2026 at 1:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 7:15am
It has been converted from 6 Volt to 12 Volt
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 7:21am
I think I might have an Englisch build (EB) version Confused
The letters are not visible on the block
Englisch build 1953 B's have serial numbers between EB9200 and EB11120 (That's what I find on the internet)
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 7:27am
England imported some tractors and then some "KITS" to build theirself. I dont know the full story, but your right.. some had English serial numbers... I think they tried to use some parts made in the UK... You might have LUCAS starter / generator ... and some parts might look Similar, but be Different than a US made tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 7:44am
there are a couple guys on here from the UK. Mark Everett comes to mind. Dont see him post much, but comes to read routinely.. He would be a LOT BETTER at giving you more details on this tractor..
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 4:49pm
Is there a Rev counter that works with the Fairbanks Morse FM Magneto?
And how do you connect it?
Edited by PeterVD - 15 Jan 2026 at 4:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 4:53pm
no, there is no RPM indicator for the B tractors.. You would have to get an aftermarket unit that counts PULSES on a 4 cylinder engine..... nobody really worries about the RPM much... not a big deal in the long run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 11:31am
Today put a new condenser in the magneto, adjusted the timing, new spark plug wires and new spark plug, sounds ok I think
Edited by PeterVD - 18 Jan 2026 at 11:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 12:55pm
YEP... sounds like your doing GREAT !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 3:24pm
Thanks Steve Wink
I only have one small problem with it now, the choke has to stay a little bit closed to keep it running, when I open the choke completely the motor drops dead
I hope a good clean of the carburator will help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 3:43pm
Thanks Steve Wink
Or the felt air seals for the choke shaft...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 4:00pm
Thanks Steve Wink
Do you have a parts number for the felt air seals please?
Is it any of these:
Edited by PeterVD - 18 Jan 2026 at 4:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 6:43pm
you can normally grab the arm on the shaft and try to WOBBLE IT... If you got a couple thousandths clearance, thats OK... If you got  30 thousands clearance, you could be sucking air around the shaft...Also a leaking manifold gasket can do that.... But i would agree with you that 90% of the time it is a partially plugged main jet / crud in the carb.
